Available servers for running Aerial
We are planning to have a Aerial Testbed in our lab for OTA testing.
Is there any availble servers that supoort that?
The Grace hopper server listed is a discontinued SKU and we cannot find any vendors in Europe.
We want production grade deployment so DGX spark is not good enough.
Thanks @cl3 for your question. Could you please confirm what you mean ‘production grade’ deployment.
We just want a server that can be used in the actual RAN deployment.
Thanks @cl3. Yes, GH200 is EOL. DGX Spark will work if the use case is 1-4 cells and Daisy chaining them will enable more cells.
Here’s the qualified hardware for Aerial Testbed: Part 1. Procure the Hardware — Aerial Testbed.
Also, OAIBOX is a Europe-based supplier (both GH200 and DGX Spark) that you can consider although we have not qualified their equipment. They work with universities and research institutions to help setup testbeds.
Thanks for your info.
Will GH200 work in the next 3-5 years?
When will we have support for blackwell/ Vera Rubin?
Thanks @cl3 for the question.
As GH200 is widely adopted within the developer and research community, we will continue to support it through to at least 2027.
There is no confirmation for support for Blackwell or Vera Rubin.
