AWS AMI/Volume fails with new quickstart
Hardware - GPU (T4)
Hardware - CPU
Operating System - ubuntu
Riva Version - 2.5
How to reproduce the issue?
So with previous Riva versions, I could create AMIs from instances and use them again perfectly. Now when you make an instance with the new 2.5 quickstart the speech server builds and everything is working, I then create an image/volume of this to use again later. But when I run Riva start on a new instance it times out and won’t start like the previous versions of Riva, I’m moving from 1.8 to 2.5 am I missing something? (everything works on the original instance using 2.5)
Logs:
Copyright (c) 2018-2022, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES.  All rights reserved.
This container image and its contents are governed by the NVIDIA Deep Learning Container License.
By pulling and using the container, you accept the terms and conditions of this license:
https://developer.nvidia.com/ngc/nvidia-deep-learning-container-license
  > Riva waiting for Triton server to load all models...retrying in 1 second
I0916 20:52:21.733615 103 onnxruntime.cc:2400] TRITONBACKEND_Initialize: onnxruntime
I0916 20:52:21.733736 103 onnxruntime.cc:2410] Triton TRITONBACKEND API version: 1.9
I0916 20:52:21.734393 103 onnxruntime.cc:2416] 'onnxruntime' TRITONBACKEND API version: 1.9
I0916 20:52:21.734406 103 onnxruntime.cc:2446] backend configuration:
I0916 20:52:22.944714 103 pinned_memory_manager.cc:240] Pinned memory pool is created at '0x7f12b0000000' with size 268435456
I0916 20:52:22.947275 103 cuda_memory_manager.cc:105] CUDA memory pool is created on device 0 with size 1000000000
I0916 20:52:22.980826 103 model_repository_manager.cc:1077] loading: conformer-en-US-asr-streaming-throughput-ctc-decoder-cpu-streaming:1
I0916 20:52:23.081141 103 model_repository_manager.cc:1077] loading: conformer-en-US-asr-streaming-throughput-feature-extractor-streaming:1
I0916 20:52:23.181410 103 model_repository_manager.cc:1077] loading: conformer-en-US-asr-streaming-throughput-voice-activity-detector-ctc-streaming:1
I0916 20:52:23.281665 103 model_repository_manager.cc:1077] loading: riva-punctuation-en-US:1
I0916 20:52:23.381930 103 model_repository_manager.cc:1077] loading: riva-trt-conformer-en-US-asr-streaming-throughput-am-streaming:1
I0916 20:52:23.482185 103 model_repository_manager.cc:1077] loading: riva-trt-riva-punctuation-en-US-nn-bert-base-uncased:1
I0916 20:52:28.644020 103 ctc-decoder-library.cc:20] TRITONBACKEND_ModelInitialize: conformer-en-US-asr-streaming-throughput-ctc-decoder-cpu-streaming (version 1)
WARNING: Logging before InitGoogleLogging() is written to STDERR
W0916 20:52:28.760057   124 parameter_parser.cc:120] Parameter forerunner_start_offset_ms could not be set from parameters
W0916 20:52:28.760085   124 parameter_parser.cc:121] Default value will be used
W0916 20:52:28.760092   124 parameter_parser.cc:120] Parameter use_vad could not be set from parameters
W0916 20:52:28.760095   124 parameter_parser.cc:121] Default value will be used
W0916 20:52:28.760214   124 parameter_parser.cc:120] Parameter forerunner_start_offset_ms could not be set from parameters
W0916 20:52:28.760222   124 parameter_parser.cc:121] Default value will be used
W0916 20:52:28.760227   124 parameter_parser.cc:120] Parameter max_num_slots could not be set from parameters
W0916 20:52:28.760231   124 parameter_parser.cc:121] Default value will be used
W0916 20:52:28.760238   124 parameter_parser.cc:120] Parameter use_vad could not be set from parameters
W0916 20:52:28.760242   124 parameter_parser.cc:121] Default value will be used
I0916 20:52:28.762616 103 backend_model.cc:255] model configuration:
    "name": "conformer-en-US-asr-streaming-throughput-ctc-decoder-cpu-streaming",
    "platform": "",
    "backend": "riva_asr_decoder",
    "version_policy": {
        "latest": {
            "num_versions": 1
    "max_batch_size": 1024,
    "input": [
            "name": "CLASS_LOGITS",
            "data_type": "TYPE_FP32",
            "format": "FORMAT_NONE",
            "dims": [
                -1,
                257
            "is_shape_tensor": false,
            "allow_ragged_batch": false,
            "optional": false
            "name": "END_FLAG",
            "data_type": "TYPE_UINT32",
            "dims": [
                1
            "optional": false
            "name": "SEGMENTS_START_END",
            "dims": [
                -1,
                2
            "optional": false
            "name": "CUSTOM_CONFIGURATION",
            "data_type": "TYPE_STRING",
            "dims": [
                -1,
                2
            "optional": false
    "output": [
            "name": "FINAL_TRANSCRIPTS",
            "dims": [
                -1
            "label_filename": "",
            "name": "FINAL_TRANSCRIPTS_SCORE",
            "dims": [
                -1
            "name": "FINAL_WORDS_START_END",
            "data_type": "TYPE_INT32",
            "dims": [
                -1,
                2
            "name": "PARTIAL_TRANSCRIPTS",
            "dims": [
                -1
            "name": "PARTIAL_TRANSCRIPTS_STABILITY",
            "dims": [
                -1
            "name": "PARTIAL_WORDS_START_END",
            "dims": [
                -1,
                2
    "batch_input": [],
    "batch_output": [],
    "optimization": {
        "graph": {
            "level": 0
        "priority": "PRIORITY_DEFAULT",
        "cuda": {
            "graphs": false,
            "busy_wait_events": false,
            "graph_spec": [],
            "output_copy_stream": true
        "input_pinned_memory": {
            "enable": true
        "output_pinned_memory": {
            "enable": true
        "gather_kernel_buffer_threshold": 0,
        "eager_batching": false
    "sequence_batching": {
        "oldest": {
            "max_candidate_sequences": 1024,
            "preferred_batch_size": [
                32,
                64
            "max_queue_delay_microseconds": 1000
        "max_sequence_idle_microseconds": 60000000,
        "control_input": [
                "name": "START",
                "control": [
                        "kind": "CONTROL_SEQUENCE_START",
                        "int32_false_true": [
                            0,
                            1
                        "fp32_false_true": [],
                        "bool_false_true": [],
                        "data_type": "TYPE_INVALID"
                "name": "READY",
                "control": [
                        "kind": "CONTROL_SEQUENCE_READY",
                            0,
                            1
                "name": "END",
                "control": [
                        "kind": "CONTROL_SEQUENCE_END",
                            0,
                            1
                "name": "CORRID",
                "control": [
                        "kind": "CONTROL_SEQUENCE_CORRID",
                        "int32_false_true": [],
                        "data_type": "TYPE_UINT64"
        "state": []
    "instance_group": [
            "name": "conformer-en-US-asr-streaming-throughput-ctc-decoder-cpu-streaming_0",
            "kind": "KIND_CPU",
            "count": 1,
            "gpus": [],
            "secondary_devices": [],
            "profile": [],
            "passive": false,
            "host_policy": ""
    "default_model_filename": "",
    "cc_model_filenames": {},
    "metric_tags": {},
    "parameters": {
        "set_default_index_to_unk_token": {
            "string_value": "False"
        "decoder_type": {
            "string_value": "flashlight"
        "forerunner_beam_size": {
            "string_value": "8"
        "unk_score": {
            "string_value": "-inf"
        "chunk_size": {
            "string_value": "0.8"
        "max_supported_transcripts": {
            "string_value": "1"
        "lexicon_file": {
            "string_value": "/data/models/conformer-en-US-asr-streaming-throughput-ctc-decoder-cpu-streaming/1/lexicon.txt"
        "smearing_mode": {
            "string_value": "max"
        "log_add": {
            "string_value": "True"
        "lm_weight": {
        "blank_token": {
            "string_value": "#"
        "vocab_file": {
            "string_value": "/data/models/conformer-en-US-asr-streaming-throughput-ctc-decoder-cpu-streaming/1/riva_decoder_vocabulary.txt"
        "ms_per_timestep": {
            "string_value": "40"
        "use_subword": {
        "streaming": {
        "beam_size": {
            "string_value": "32"
        "right_padding_size": {
            "string_value": "1.6"
        "beam_size_token": {
            "string_value": "16"
        "sil_token": {
            "string_value": "▁"
        "num_tokenization": {
            "string_value": "1"
        "beam_threshold": {
            "string_value": "20.0"
        "language_model_file": {
            "string_value": "/data/models/conformer-en-US-asr-streaming-throughput-ctc-decoder-cpu-streaming/1/en_4.0.bin"
        "tokenizer_model": {
            "string_value": "/data/models/conformer-en-US-asr-streaming-throughput-ctc-decoder-cpu-streaming/1/8b8f095152034e98b24ab33726708bd0_tokenizer.model"
        "max_execution_batch_size": {
            "string_value": "1024"
        "forerunner_use_lm": {
            "string_value": "true"
        "forerunner_beam_size_token": {
            "string_value": "8"
        "profane_words_file": {
            "string_value": "/data/models/conformer-en-US-asr-streaming-throughput-ctc-decoder-cpu-streaming/1/profane_words_file.txt"
        "forerunner_beam_threshold": {
            "string_value": "10.0"
        "decoder_num_worker_threads": {
            "string_value": "-1"
        "asr_model_delay": {
        "word_insertion_score": {
            "string_value": "1.0"
        "unk_token": {
            "string_value": "<unk>"
        "left_padding_size": {
    "model_warmup": [],
    "model_transaction_policy": {
        "decoupled": false
I0916 20:52:29.001164 103 feature-extractor.cc:399] TRITONBACKEND_ModelInitialize: conformer-en-US-asr-streaming-throughput-feature-extractor-streaming (version 1)
W0916 20:52:29.002691   125 parameter_parser.cc:120] Parameter is_dither_seed_random could not be set from parameters
W0916 20:52:29.002708   125 parameter_parser.cc:121] Default value will be used
W0916 20:52:29.002712   125 parameter_parser.cc:120] Parameter max_batch_size could not be set from parameters
W0916 20:52:29.002714   125 parameter_parser.cc:121] Default value will be used
W0916 20:52:29.002717   125 parameter_parser.cc:120] Parameter max_sequence_idle_microseconds could not be set from parameters
W0916 20:52:29.002719   125 parameter_parser.cc:121] Default value will be used
W0916 20:52:29.002724   125 parameter_parser.cc:120] Parameter preemph_coeff could not be set from parameters
W0916 20:52:29.002728   125 parameter_parser.cc:121] Default value will be used
I0916 20:52:29.544552 103 backend_model.cc:255] model configuration:
    "name": "conformer-en-US-asr-streaming-throughput-feature-extractor-streaming",
    "platform": "",
    "backend": "riva_asr_features",
    "version_policy": {
        "latest": {
            "num_versions": 1
    "input": [
            "name": "AUDIO_SIGNAL",
            "dims": [
                -1
            "optional": false
            "name": "SAMPLE_RATE",
            "dims": [
                1
            "optional": false
    "output": [
            "name": "AUDIO_FEATURES",
            "dims": [
                80,
                -1
            "name": "AUDIO_PROCESSED",
            "dims": [
                1
            "name": "AUDIO_FEATURES_LENGTH",
            "dims": [
                1
    "batch_input": [],
    "batch_output": [],
    "optimization": {
        "graph": {
            "level": 0
        "cuda": {
            "graphs": false,
            "graph_spec": [],
            "enable": true
            "enable": true
        "oldest": {
                256,
                512
        "control_input": [
                "name": "START",
                "control": [
                            0,
                            1
                "name": "READY",
                "control": [
                            0,
                            1
                "name": "END",
                "control": [
                            0,
                            1
                "name": "CORRID",
                "control": [
        "state": []
    "instance_group": [
            "name": "conformer-en-US-asr-streaming-throughput-feature-extractor-streaming_0",
            "kind": "KIND_GPU",
            "count": 1,
            "gpus": [
                0
            "profile": [],
            "passive": false,
            "host_policy": ""
    "metric_tags": {},
    "parameters": {
        "num_features": {
            "string_value": "80"
        "window_size": {
            "string_value": "0.025"
        "window_stride": {
            "string_value": "0.01"
        "streaming": {
        "stddev_floor": {
            "string_value": "1e-05"
        "transpose": {
        "gain": {
        "use_utterance_norm_params": {
        "precalc_norm_time_steps": {
            "string_value": "0"
        "precalc_norm_params": {
        "dither": {
        "norm_per_feature": {
        "mean": {
            "string_value": "-11.4412,  -9.9334,  -9.1292,  -9.0365,  -9.2804,  -9.5643,  -9.7342, -9.6925,  -9.6333,  -9.2808,  -9.1887,  -9.1422,  -9.1397,  -9.2028, -9.2749,  -9.4776,  -9.9185, -10.1557, -10.3800, -10.5067, -10.3190, -10.4728, -10.5529, -10.6402, -10.6440, -10.5113, -10.7395, -10.7870, -10.6074, -10.5033, -10.8278, -10.6384, -10.8481, -10.6875, -10.5454, -10.4747, -10.5165, -10.4930, -10.3413, -10.3472, -10.3735, -10.6830, -10.8813, -10.6338, -10.3856, -10.7727, -10.8957, -10.8068, -10.7373, -10.6108, -10.3405, -10.2889, -10.3922, -10.4946, -10.3367, -10.4164, -10.9949, -10.7196, -10.3971, -10.1734,  -9.9257,  -9.6557,  -9.1761, -9.6653,  -9.7876,  -9.7230,  -9.7792,  -9.7056,  -9.2702,  -9.4650, -9.2755,  -9.1369,  -9.1174,  -8.9197,  -8.5394,  -8.2614,  -8.1353, -8.1422,  -8.3430,  -8.6655"
        "stddev": {
            "string_value": "2.2668, 3.1642, 3.7079, 3.7642, 3.5349, 3.5901, 3.7640, 3.8424, 4.0145, 4.1475, 4.0457, 3.9048, 3.7709, 3.6117, 3.3188, 3.1489, 3.0615, 3.0362, 2.9929, 3.0500, 3.0341, 3.0484, 3.0103, 2.9474, 2.9128, 2.8669, 2.8332, 2.9411, 3.0378, 3.0712, 3.0190, 2.9992, 3.0124, 3.0024, 3.0275, 3.0870, 3.0656, 3.0142, 3.0493, 3.1373, 3.1135, 3.0675, 2.8828, 2.7018, 2.6296, 2.8826, 2.9325, 2.9288, 2.9271, 2.9890, 3.0137, 2.9855, 3.0839, 2.9319, 2.3512, 2.3795, 2.6191, 2.7555, 2.9326, 2.9931, 3.1543, 3.0855, 2.6820, 3.0566, 3.1272, 3.1663, 3.1836, 3.0018, 2.9089, 3.1727, 3.1626, 3.1086, 2.9804, 3.1107, 3.2998, 3.3697, 3.3716, 3.2487, 3.1597, 3.1181"
        "chunk_size": {
        "sample_rate": {
            "string_value": "16000"
    "model_warmup": [],
        "decoupled": false
I0916 20:52:29.544638 103 ctc-decoder-library.cc:23] TRITONBACKEND_ModelInstanceInitialize: conformer-en-US-asr-streaming-throughput-ctc-decoder-cpu-streaming_0 (device 0)
  > Timed out.
  > Triton server died before reaching ready state. Terminating Riva startup.
Hi @HansieB
Thanks for your interest in Riva
Apologies you are facing issue
Thanks for sharing the logs
I will check with the team regarding this issue and provide an update
I’m seeing a similar issue. First time I run riva_start.sh on an instance created from an image with Riva, it times out but it succeeds when I run it for the second time.
Hi @HansieB and @petra1
I am tracking this internally and the folks are evaluating,
Just initial inputs as of now, not confirming,
It may be due to IOPS speed of the AMI disk
Will update in thread once i have update
Thanks for the response, let me know if I can help in any way.
I think I’ve tried both gp2 and gp3 AWS volume types but got the same result.
I’ve been playing around with different IOPS for the volumes but it doesn’t seem to have any effect.
In the meantime for anyone facing this just add the --restart unless-stopped flag in the docker run command. The second docker run always works but now a new instance takes about 5 minutes to start.
I’m open to any suggestions on how to fix this if anyone else is also using aws volumes
Hi @HansieB
Apologies for the long delay
I have the results from the team, please find below
It sounds like the filesystem as exposed from AWS is representing it has files but they either are too slow or some show other exceptional behaviour.
I would like the customer to open a ticket with AWS and see what they come back with.
