• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 5.1
• JetPack Version (valid for Jetson only) 4.5
• TensorRT Version 7.1
• Issue Type( questions, new requirements, bugs) questions
• How to reproduce the issue ?
I’m currently working on a custom pipeline created with the python-bindings.
The general architecture of the pipeline goes like this:
uridecodebins (3) → streamMuxer → pgie → tracker → demuxer (3) ->nvvidconvert → nvdsosd → tee → transformer → glsink
→ msgconv → msgbroker
The MQTT configuration was successfully built following this tutorial How to integrate NVIDIA DeepStream on Jetson Modules with AWS IoT Core and AWS IoT Greengrass.
The app worked fine at first with the desired output, and the MQTT messages been published to the desired TOPIC.
After a few days and without any changes in the code or configuration, the code hangs for around 20 minutes in the “Using winsys x 11” log after the pipeline loop starts.
I will note that I changed of place (IP, Internet connection)
After 20 minutes the app runs okay.
Any idea how can I fix this?
