AX210 / BE200 Intel wireless devices: Invalid rxb from HW <vid>
We discovered a bug with our AX210 / BE200 devices:
[21422.847958] ------------[ cut here ]------------
[21422.847973] frame on invalid queue - is on 7 and indicates 3
[21422.848113] WARNING: CPU: 4 PID: 493 at /home/ecg_orin_agx/wireless/core24.70/backport-iwlwifi/drivers/net/wireless/intel/iwlwifi/pcie/gen1_2/rx.c:1345 iwl_pcie_rx_handle+0x714/0xc20 [iwlwifi]
[21422.848180] Modules linked in: xt_conntrack xt_MASQUERADE ip6table_nat ip6table_filter ip6_tables xt_set ip_set iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 xt_addrtype iptable_filter nvidia_drm(O) nvidia_modeset(O) nf_tables libcrc32c nfnetlink algif_hash algif_skcipher af_alg bnep iwlmvm(OE) nvme_fabrics mac80211(OE) libarc4 lzo_rle lzo_compress zram zsmalloc ramoops reed_solomon bridge stp llc usb_f_ncm usb_f_mass_storage usb_f_acm u_serial usb_f_rndis u_ether libcomposite rtk_btusb(O) btusb btrtl btintel btbcm snd_soc_tegra186_asrc(O) snd_soc_tegra210_ope(O) snd_soc_tegra210_admaif(O) snd_soc_tegra186_dspk(O) snd_soc_tegra186_arad(O) snd_soc_tegra210_afc(O) snd_soc_tegra_pcm snd_soc_tegra210_mixer(O) snd_soc_tegra210_mvc(O) snd_soc_tegra210_dmic(O) snd_soc_tegra210_adx(O) snd_soc_tegra210_sfc(O) snd_soc_tegra210_amx(O) snd_soc_tegra210_i2s(O) snd_soc_tegra210_ahub(O) tegra210_adma spidev nvvrs_pseq_rtc(O) crct10dif_ce snd_soc_tegra_machine_driver(O)
[21422.848240]  snd_soc_tegra_utils(O) snd_soc_simple_card_utils tegra23x_perf_uncore(O) tegra234_oc_event(O) nvpmodel_clk_cap(O) tegra_mce(O) mttcan(O) thermal_trip_event(O) tegra_cactmon_mc_all(O) can_dev nvethernet(O) tegra234_aon(O) snd_hda_codec_hdmi tegra_aconnect nvpps(O) snd_hda_tegra iwlwifi(OE) snd_soc_rt5640 snd_hda_codec cfg80211(OE) snd_hda_core pwm_tegra_tachometer(O) snd_soc_rl6231 at24 spi_tegra114 compat(OE) mc_hwpm(O) nvidia(O) nvidia_vrs_pseq(O) i2c_nvvrs11(O) lm90 host1x_fence(O) tegra_dce(O) nvhost_isp5(O) nvhost_vi5(O) nvhost_nvcsi_t194(O) tegra_pcie_dma_test(O) tegra_pcie_edma(O) tegra_camera(O) v4l2_dv_timings nvhost_nvcsi(O) tegra_camera_platform(O) capture_ivc(O) tegra_camera_rtcpu(O) ivc_bus(O) hsp_mailbox_client(O) ivc_ext(O) governor_userspace v4l2_fwnode v4l2_async videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videobuf2_common tegra_drm(O) videodev tegra_wmark(O) nvhost_pva(O) nvhost_nvdla(O) mc cec nvhwpm(O) nvhost_capture(O) tegra_se(O)
[21422.848320]  host1x_nvhost(O) drm_kms_helper tsecriscv(O) crypto_engine tpm_ftpm_tee nvidia_p2p(O) ina3221 nvgpu(O) governor_pod_scaling(O) host1x(O) mc_utils(O) nvmap(O) nvsciipc(O) fuse drm ip_tables x_tables ipv6 pwm_fan pwm_tegra tegra_bpmp_thermal tegra_xudc ucsi_ccg typec_ucsi typec nvme nvme_core phy_tegra194_p2u pcie_tegra194
[21422.848366] CPU: 4 PID: 493 Comm: irq/268-iwlwifi Tainted: G           OE     5.15.185-tegra #1
[21422.848373] Hardware name: NVIDIA NVIDIA Jetson AGX Orin Developer Kit/Jetson, BIOS 36.5.0-gcid-43688277 01/16/2026
[21422.848377] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[21422.848381] pc : iwl_pcie_rx_handle+0x714/0xc20 [iwlwifi]
[21422.848407] lr : iwl_pcie_rx_handle+0x714/0xc20 [iwlwifi]
[21422.848424] sp : ffff80000ceab9f0
[21422.848425] x29: ffff80000ceabb00 x28: ffff0000ecf15000 x27: ffff0000b03a2300
[21422.848427] x26: ffff00008c61c080 x25: ffff000085f9d0d0 x24: 0000000000000000
[21422.848429] x23: 0000000000001000 x22: 00000000000000c1 x21: ffff0000b48507c0
[21422.848432] x20: 0000000000008830 x19: 0000000000000000 x18: ffffffffffffffff
[21422.848434] x17: 0000000000200300 x16: ffffca0932532410 x15: ffffca0933e802fa
[21422.848436] x14: 0000000000000000 x13: ffffca0933e802f7 x12: 2065756575712064
[21422.848439] x11: 656820747563205b x10: 000000000000000a x9 : ffff80000ceab9f0
[21422.848442] x8 : 000000000000000a x7 : 2073657461636964 x6 : 000000000000000a
[21422.848445] x5 : ffff000fa2c0fa00 x4 : 00000000fffff3b0 x3 : ffffca0933ae9580
[21422.848447] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0000822f0000
[21422.848450] Call trace:
[21422.848453]  iwl_pcie_rx_handle+0x714/0xc20 [iwlwifi]
[21422.848470]  iwl_pcie_napi_poll_msix+0x48/0xf0 [iwlwifi]
[21422.848487]  __napi_poll+0x48/0x230
[21422.848508]  net_rx_action+0xf4/0x290
[21422.848512]  handle_softirqs+0x128/0x390
[21422.848521]  do_softirq+0x94/0xa0
[21422.848523]  __local_bh_enable_ip+0xb8/0xd0
[21422.848526]  iwl_pcie_irq_rx_msix_handler+0xd8/0x210 [iwlwifi]
[21422.848543]  irq_thread_fn+0x38/0xd0
[21422.848549]  irq_thread+0x1ac/0x320
[21422.848551]  kthread+0x184/0x1a0
[21422.848555]  ret_from_fork+0x10/0x20
[21422.848560] ---[ end trace 36f87f4c942a53d2 ]---
[21422.880129] ------------[ cut here ]------------
The fix is down there. We are right now reviewing it and sending it upstream.
diff --git a/drivers/net/wireless/intel/iwlwifi/pcie/rx.c b/drivers/net/wireless/intel/iwlwifi/pcie/rx.c
index cf9dc736fe80..167d02958019 100644
--- a/drivers/net/wireless/intel/iwlwifi/pcie/rx.c
+++ b/drivers/net/wireless/intel/iwlwifi/pcie/rx.c
@@ -1519,6 +1519,11 @@ restart:
r = iwl_get_closed_rb_stts(trans, rxq);
i = rxq->read;
/* Order the read of the write pointer before any read of the
completion descriptors and of the RB contents it makes visible.
dma_rmb();
/* W/A 9000 device step A0 wrap-around bug */
r &= (rxq->queue_size - 1);
2.55.0
Many thanks for the sharing. So the patch is for Jetpack 6.2.2 r36.5? Would like to confirm the Jetpack version.
To be honest, I don’t really understand how the Jetpack versioning works.
This should be applied on our driver inside the kernel or on our backport trees.
This fix is currently under review and once it is merged, it’ll be available in our backport tree ( https://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/backport-iwlwifi.git/ )
The fix was merged into our backport tree:
