— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
Based on the provided context, it appears that the Jetson AGX Orin is entering recovery mode automatically when the USB Type-C cable is connected and powered on, without the need to hold the recovery button. This behavior is not explicitly mentioned in the provided context as a normal or expected behavior.
However, it is mentioned in the context that the USB Type-C port next to the 40-pin header can act as a UFP (Up-stream Facing Port) and is used for flashing the device. It is also mentioned that the device can be put into recovery mode by holding the recovery button and powering on the device.
Given this information, it is possible that the device is being put into recovery mode due to a hardware issue or a configuration problem. To troubleshoot this issue, you may want to try the following:
- Check the USB Type-C cable and port for any damage or issues.
- Try using a different USB Type-C cable or port to see if the issue persists.
- Check the device’s configuration and settings to see if there are any options to disable the automatic recovery mode.
- Try flashing the device with a different JetPack version to see if the issue is specific to a particular version.
If none of these steps resolve the issue, it may be worth contacting NVIDIA support for further assistance.
In terms of disabling the automatic recovery mode, there is no clear information in the provided context on how to do this. However, it is mentioned that the device can be put into recovery mode by holding the recovery button and powering on the device, which suggests that there may be a way to disable this behavior through the device’s configuration or settings.
It is also worth noting that the issue only occurs when the device is powered on after a shutdown, and not when the device is rebooted. This suggests that the issue may be related to the device’s boot process or configuration.
Overall, while the provided context does not provide a clear solution to this issue, it does suggest that the device’s behavior is not normal and may be due to a hardware or configuration problem. Further troubleshooting and investigation may be necessary to resolve the issue.
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
