Hi
Is there a way to get higher performance of running back-to-back-detectors with Deepstream5.0 on NX?
We tested back-to-back-detectors with DS5 on NX and got not smooth inference result. The speed might be lower than 15 FPS.
Also the GPU usage was around 99%. (see attached.)
Already set nvpmodel to 2 and enabled jetson-clock.
Moreover, modifying interval did not see any change.
Is it normal?
Thank you for any advice,
