Backup and restore not working
I’m trying to backup Orin Nano which has Jetpack 5.1.1 using this command but getting errors
sudo ./tools/backup_restore/l4t_backup_restore.sh -b jetson-orin-nano-devkit
flash_3-7_0_20240315-113617.log (6.9 KB)
What are you using?
SD card/NVMe drive/USB drive?
SD card on dev board
Then you should add -e mmcblk1 to the command.
SD card on Orin Nano is recognized as mmcblk1 instead of mmcblk0 on JetPack 5.
Getting this error when I added it
sudo ./tools/backup_restore/l4t_backup_restore.sh -b jetson-orin-nano-devkit -e mmcblk1
/home/valorrobotics/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --initrd --showlogs mmcblk1 mmcblk0p1
/home/valorrobotics/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 47: /home/valorrobotics/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/mmcblk1.conf: No such file or directory
/home/valorrobotics/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash.func: line 194: /home/valorrobotics/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/mmcblk1.conf: No such file or directory
*  Step 1: Generate rcm boot commandline *
/home/valorrobotics/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/flash.sh  --no-flash --rcm-boot mmcblk1 mmcblk0p1
Error: Invalid target board - mmcblk1.
Usage: sudo ./flash.sh [options] <target_board> <rootdev>
  Where,
	target board: Valid target board name.
	rootdev: Proper root device.
    options:
        -c <cfgfile> ---------- Flash partition table config file.
        -d <dtbfile> ---------- device tree file.
        -f <flashapp> --------- Path to flash application (tegraflash.py)
        -h -------------------- print this message.
        -i <enc rfs key file>-- key for disk encryption support.
        -k <partition id> ----- partition name or number specified in flash.cfg.
        -m <mts preboot> ------ MTS preboot such as mts_preboot_si.
        -n <nfs args> --------- Static nfs network assignments
                                <Client IP>:<Server IP>:<Gateway IP>:<Netmask>
        -o <odmdata> ---------- ODM data.
        -r -------------------- skip building and reuse existing system.img.
        -t <tegraboot> -------- tegraboot binary such as nvtboot.bin
        -u <PKC key file>------ PKC key used for odm fused board.
        -v <SBK key file>------ Secure Boot Key (SBK) key used for ODM fused board.
        -w <wb0boot> ---------- warm boot binary such as nvtbootwb0.bin
        -x <tegraid> ---------- Tegra CHIPID.
        -B <boardid> ---------- BoardId.
        -C <cmdline> ---------- Kernel commandline arguments.
                                WARNING:
                                Each option in this kernel commandline gets
                                higher preference over the values set by
                                flash.sh. In case of NFS booting, this script
                                adds NFS booting related arguments, if -i option
                                is omitted.
        -F <flasher> ---------- Flash server such as cboot.bin.
        -G <file name> -------- Read partition and save image to file.
        -I <initrd> ----------- initrd file. Null initrd is default.
        -K <kernel> ----------- Kernel image file such as zImage or Image.
        -L <bootloader> ------- Bootloader such as cboot.bin or u-boot-dtb.bin.
        -M <mts boot> --------- MTS boot file such as mts_si.
        -N <nfsroot> ---------- i.e. <my IP addr>:/my/exported/nfs/rootfs.
        -R <rootfs dir> ------- Sample rootfs directory.
        -S <size> ------------- Rootfs size in bytes. Valid only for internal
                                rootdev. KiB, MiB, GiB short hands are allowed,
                                for example, 1GiB means 1024 * 1024 * 1024 bytes.
        -Z -------------------- Print configurations and then exit.
        --no-flash ------------ perform all steps except physically flashing the board.
                                This will create a system.img.
        --external-device------ Generate flash images for external devices
        --sparseupdate--------- only flash partitions that have changed. Currently only support SPI flash memory
        --no-systemimg -------- Do not create or re-create system.img.
        --bup ----------------- Generate bootloader update payload(BUP).
        --single-image-bup <part name> Generate specified single image BUP, this must work with --bup.
        --bup-type <type> ----- Generate specific type bootloader update payload(BUP), such as bl or kernel.
        --multi-spec----------- Enable support for building multi-spec BUP.
        --clean-up------------- Clean up BUP buffer when multi-spec is enabled.
        --usb-instance <id> --- Specify the USB instance to connect to;
                                <id> = USB port path (e.g. 3-14).
        --no-root-check ------- Typical usage of this script require root permissions.
                                Pass this option to allow running the script as a
                                regular user, in which case only specific combinations
                                of command-line options will be functional.
        --user_key <key_file>   User provided key file (16-byte) to encrypt user images,
                                like kernel, kernel-dtb and initrd.
                                If user_key is specified, SBK key (-v) has to be specified.
                                For now, user_key file must contain all 0's.
        --uefi-keys <keys_conf> Specify UEFI keys configuration file.
        --rcm-boot ------------ Do RCM boot instead of physically flashing the board.
        --sign ---------------- Sign images and store them under "bootloader/signed"
                                directory. The board will not be physically flashed.
        --image --------------- Specify the image to be written into board.
        --boot-chain-flash <c>  Flash only a specific boot chain (ex. "A, "B", "all").
                                Defaults to "all", inputs are case insensitive.
                                Not suitable for production.
        --boot-chain-select <c> Specify booting chain (ex. "A" or "B") after the board is flashed.
                                Defaults to "A", inputs are case insensitive.
        --pv-crt -------------- The certificate for the key that is used to sign cpu_bootloader
Cleaning up...
sudo ./tools/backup_restore/l4t_backup_restore.sh -b -e mmcblk1 jetson-orin-nano-devkit
, not
Anyway, I just noticed this option is added starting from 5.1.2, and it’s not available in 5.1.1.
Then please replace every instance of mmcblk0 with mmcblk1 in nvbackup_partitions.sh and nvrestore_partitions.sh.
