Here you are :
[0000.240] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.245] Processing in cold boot mode Bootloader 2
[0000.250] A02 Bootrom Patch rev = 1023
[0000.253] Power-up reason: pmc por
[0000.257] No Battery Present
[0000.259] pmic max77620 reset reason
[0000.263] pmic max77620 NVERC : 0x50
[0000.266] RamCode = 0
[0000.268] Platform has DDR4 type RAM
[0000.272] max77620 disabling SD1 Remote Sense
[0000.276] Setting DDR voltage to 1125mv
[0000.280] Serial Number of Pmic Max77663: 0x1e37ed
[0000.287] Entering ramdump check
[0000.290] Get RamDumpCarveOut = 0x0
[0000.294] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.299] Last reboot was clean, booting normally!
[0000.303] Sdram initialization is successful
[0000.308] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.314] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.319] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.325] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.331] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.337] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.343] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.349] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.365] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.371] Platform-DebugCarveout: 0
[0000.374] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.380] Non secure mode, and RB not enabled.
[0000.384] *** Booting BFS0.
[0000.387] Initialize FailControl
[0000.390] Read PT from (0:3)
[0000.405] Csd NumOfBlocks=0
[0000.444] PT crc32 and magic check passed.
[0000.448] Using BFS PT to query partitions
[0000.452] PT: Partition LNX NOT found !
[0000.456] *** Booting KFS0.
[0000.458] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.464] BoardID = 3448, SKU = 0x2
[0000.468] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.473] Read GPT from (0:3)
[0000.482] Using GPT Primary to query partitions
[0000.486] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.492] Loading Tboot-CPU binary
[0000.498] Verifying TBC in OdmNonSecureSBK mode
[0000.508] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.515] Bootloader downloaded successfully.
[0000.519] Downloaded Tboot-CPU binary to 0xa0000258
[0000.525] MAX77620_GPIO5 configured
[0000.528] CPU power rail is up
[0000.531] CPU clock enabled
[0000.534] Performing RAM repair
[0000.537] Updating A64 Warmreset Address to 0xa00002e9
[0000.542] BoardID = 3448, SKU = 0x2
[0000.546] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.552] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.558] Loading NvTbootBootloaderDTB
[0000.575] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.629] Bootloader DTB Load Address: 0x83000000
[0000.633] BoardID = 3448, SKU = 0x2
[0000.636] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.642] Loading NvTbootKernelDTB
[0000.659] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.726] Kernel DTB Load Address: 0x83100000
[0000.731] BoardID = 3448, SKU = 0x2
[0000.734] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.740] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.747] Loading cboot binary
[0000.758] Verifying EBT in OdmNonSecureSBK mode
[0000.800] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.807] Bootloader downloaded successfully.
[0000.811] BoardID = 3448, SKU = 0x2
[0000.814] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.820] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.826] PT: Partition NCT NOT found !
[0000.830] Warning: Find Partition via PT Failed
[0000.834] Next binary entry address: 0x92c00258
[0000.839] BoardId: 3448
[0000.843] Overriding pmu board id with proc board id
[0000.848] Display board id is not available
[0000.852] BoardID = 3448, SKU = 0x2
[0000.856] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.862] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.875] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.928] /bpmp deleted
[0000.930] SC7EntryFw header found loaded at 0xff700000
[0001.126] OVR2 PMIC
[0001.128] Bpmp FW successfully loaded
[0001.132] BoardID = 3448, SKU = 0x2
[0001.135] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.141] NvTbootFailControlDoFailover: No failover; Continuing ...
[0001.148] WB0 init successfully at 0xff780000
[0001.153] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.158] Set NvDecSticky Bits
[0001.161] GSC2 address ff53fffc value c0edbbcc
[0001.167] GSC MC Settings done
[0001.170] BoardID = 3448, SKU = 0x2
[0001.174] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.180] TOS Image length 53680
[0001.183] Monitor size 53680
[0001.186] OS size 0
[0001.192] Secure Os AES-CMAC Verification Success!
[0001.196] TOS image cipher info: plaintext
[0001.200] Loading and Validation of Secure OS Successful
[0001.216] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.221] NvTbootPackSdramParams: start.
[0001.226] NvTbootPackSdramParams: done.
[0001.229] Tegraboot started after 169706 us
[0001.233] Basic modules init took 719390 us
[0001.237] Sec Bootdevice Read Time = 54 ms, Read Size = 3682 KB
[0001.243] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.249] Next stage binary read took 7392 us
[0001.253] Carveout took -34785 us
[0001.256] CPU initialization took 397600 us
[0001.260] Total time taken by TegraBoot 1089597 us
[0001.265] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):b5eeb33f7
NOTICE: BL31: Built : 12:09:37, Jul 26 2021
ERROR: Error initializing runtime service trusty_fast
[0001.387] get_emc_table_offset: failed to find EMC node
[0001.392] LPDDR4 Training: Can't find emc-table node
[0001.434]
[0001.435] Debug Init done
[0001.438] Marked DTB cacheable
[0001.441] Bootloader DTB loaded at 0x83000000
[0001.446] Marked DTB cacheable
[0001.448] Kernel DTB loaded at 0x83100000
[0001.452] DeviceTree Init done
[0001.465] Pinmux applied successfully
[0001.470] gicd_base: 0x50041000
[0001.473] gicc_base: 0x50042000
[0001.476] Interrupts Init done
[0001.480] Using base:0x60005090 & irq:208 for tick-timer
[0001.485] Using base:0x60005098 for delay-timer
[0001.490] platform_init_timer: DONE
[0001.493] Timer(tick) Init done
[0001.497] osc freq = 38400 khz
[0001.501]
[0001.502] Welcome to L4T Cboot
[0001.505]
[0001.506] Cboot Version: 00.00.2018.01-t210-c952b4e6
[0001.511] calling constructors
[0001.514] initializing heap
[0001.517] initializing threads
[0001.520] initializing timers
[0001.522] creating bootstrap completion thread
[0001.527] top of bootstrap2()
[0001.530] CPU: ARM Cortex A57
[0001.533] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.537] initializing platform
[0001.591] Config for emmc ddr50 mode completed
[0001.595] sdmmc bdev is already initialized
[0001.600] Enable APE clock
[0001.602] Un-powergate APE partition
[0001.606] of_register: registering tegra_udc to of_hal
[0001.611] of_register: registering inv20628-driver to of_hal
[0001.616] of_register: registering ads1015-driver to of_hal
[0001.622] of_register: registering lp8557-bl-driver to of_hal
[0001.628] of_register: registering bq2419x_charger to of_hal
[0001.633] of_register: registering bq27441_fuel_gauge to of_hal
[0001.645] gpio framework initialized
[0001.648] of_register: registering tca9539_gpio to of_hal
[0001.654] of_register: registering tca9539_gpio to of_hal
[0001.659] of_register: registering i2c_bus_driver to of_hal
[0001.665] of_register: registering i2c_bus_driver to of_hal
[0001.670] of_register: registering i2c_bus_driver to of_hal
[0001.676] pmic framework initialized
[0001.679] of_register: registering max77620_pmic to of_hal
[0001.685] regulator framework initialized
[0001.689] of_register: registering tps65132_bl_driver to of_hal
[0001.694] initializing target
[0001.700] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.708] board ID = D78, board SKU = 2
[0001.714] fixed regulator driver initialized
[0001.732] initializing OF layer
[0001.734] NCK carveout not present
[0001.738] Skipping dts_overrides
[0001.742] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.758] I2C Bus Init done
[0001.760] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.770] I2C Bus Init done
[0001.773] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.783] I2C Bus Init done
[0001.786] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.796] I2C Bus Init done
[0001.799] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.809] I2C Bus Init done
[0001.812] of_children_init: Ops found for compatible string maxim,max77620
[0001.822] max77620_init using irq 118
[0001.827] register 'maxim,max77620' pmic
[0001.831] gpio_driver_register: register 'max77620-gpio' driver
[0001.838] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.848] I2C Bus Init done
[0001.852] NCK carveout not present
[0001.861] Find /i2c@7000c000's alias i2c0
[0001.865] get eeprom at 1-a0, size 256, type 0
[0001.874] Find /i2c@7000c500's alias i2c2
[0001.878] get eeprom at 3-a0, size 256, type 0
[0001.882] get eeprom at 3-ae, size 256, type 0
[0001.886] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.892] I2C slave not started
[0001.895] I2C write failed
[0001.897] Writing offset failed
[0001.900] eeprom_init: EEPROM read failed
[0001.904] pm_ids_update: eeprom init failed
[0001.909] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.939] pm_ids_update: The pm board id is 3448-0002-400
[0001.945] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0001.953] pm_ids_update: pm id update successful
[0001.957] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.963] I2C slave not started
[0001.966] I2C write failed
[0001.968] Writing offset failed
[0001.971] eeprom_init: EEPROM read failed
[0001.975] pm_ids_update: eeprom init failed
[0002.005] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.011] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.019] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.025] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.033] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:d2:bd
[0002.039] Plugin Manager: Parse ODM data 0x000a4000
[0002.049] shim_cmdline_install: /chosen/bootargs: kmemleak=on earlycon=uart8250,mmio32,0x70006000
[0002.065] Find /i2c@7000c000's alias i2c0
[0002.069] get eeprom at 1-a0, size 256, type 0
[0002.078] Find /i2c@7000c500's alias i2c2
[0002.081] get eeprom at 3-a0, size 256, type 0
[0002.086] get eeprom at 3-ae, size 256, type 0
[0002.090] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.096] I2C slave not started
[0002.099] I2C write failed
[0002.101] Writing offset failed
[0002.104] eeprom_init: EEPROM read failed
[0002.108] pm_ids_update: eeprom init failed
[0002.112] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.142] pm_ids_update: The pm board id is 3448-0002-400
[0002.149] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.156] pm_ids_update: pm id update successful
[0002.160] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.166] I2C slave not started
[0002.169] I2C write failed
[0002.171] Writing offset failed
[0002.174] eeprom_init: EEPROM read failed
[0002.178] pm_ids_update: eeprom init failed
[0002.208] Add serial number:1423019115000 as DT property
[0002.215] Applying platform configs
[0002.221] platform-init is not present. Skipping
[0002.226] calling apps_init()
[0002.247] Found 17 GPT partitions in "sdmmc3_user"
[0002.252] Proceeding to Cold Boot
[0002.255] starting app android_boot_app
[0002.259] Device state: unlocked
[0002.262] display console init
[0002.267] status of sor1 node is not okay
[0002.271] sor0 is not supported
[0002.274] display_console_init: no valid display out_type
[0002.282] subnode volume_up is not found !
[0002.286] subnode back is not found !
[0002.290] subnode volume_down is not found !
[0002.294] subnode menu is not found !
[0002.297] Gpio keyboard init success
[0002.305] DT entry for leds-pwm not found
[0002.351] found decompressor handler: lz4-legacy
[0002.365] decompressing blob (type 1)...
[0002.431] display_resolution: No display init
[0002.435] Failed to retrieve display resolution
[0002.440] Could not load/initialize BMP blob...ignoring
[0002.490] decompressor handler not found
[0002.493] load_firmware_blob: Firmware blob loaded, entries=2
[0002.499] XUSB blob version 0 size 126464 @ 0x92cb328c
[0002.505] -------> se_aes_verify_sbk_clear: 747
[0002.509] se_aes_verify_sbk_clear: Error
[0002.513] SE operation failed
[0002.516] bl_battery_charging: connected to external power supply
[0002.525] display_console_ioctl: No display init
[0002.530] switch_backlight failed
[0002.539] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0002.547] MSC Partition not found
[0002.556] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0002.564] USP partition read failed!
[0002.567] blob_init: blob-partition USP header read failed
[0002.573] android_boot Unable to update recovery partition
[0002.578] kfs_getpartname: name = LNX
[0002.582] Loading kernel from LNX
[0002.675] load kernel from storage
[0002.685] decompressor handler not found
[0002.719] Successfully loaded kernel and ramdisk images
[0002.724] board ID = D78, board SKU = 2
[0002.728] display_resolution: No display init
[0002.733] Failed to retrieve display resolution
[0002.737] bmp blob is not loaded and initialized
[0002.742] Failed to display boot-logo
[0002.745] NCK carveout not present
[0002.749] Skipping dts_overrides
[0002.752] NCK carveout not present
[0002.762] Find /i2c@7000c000's alias i2c0
[0002.765] get eeprom at 1-a0, size 256, type 0
[0002.774] Find /i2c@7000c500's alias i2c2
[0002.778] get eeprom at 3-a0, size 256, type 0
[0002.783] get eeprom at 3-ae, size 256, type 0
[0002.787] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.792] I2C slave not started
[0002.795] I2C write failed
[0002.798] Writing offset failed
[0002.801] eeprom_init: EEPROM read failed
[0002.805] pm_ids_update: eeprom init failed
[0002.809] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.839] pm_ids_update: The pm board id is 3448-0002-400
[0002.846] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.854] pm_ids_update: pm id update successful
[0002.859] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.864] I2C slave not started
[0002.867] I2C write failed
[0002.870] Writing offset failed
[0002.873] eeprom_init: EEPROM read failed
[0002.877] pm_ids_update: eeprom init failed
[0002.907] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.912] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.920] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.926] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.934] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e9:d2:bd
[0002.941] Plugin Manager: Parse ODM data 0x000a4000
[0002.952] shim_cmdline_install: /chosen/bootargs: kmemleak=on earlycon=uart8250,mmio32,0x70006000
[0002.962] Add serial number:1423019115000 as DT property
[0002.970] "bpmp" doesn't exist, creating
[0002.976] Updated bpmp info to DTB
[0002.981] Updated initrd info to DTB
[0002.984] "proc-board" doesn't exist, creating
[0002.990] Updated board info to DTB
[0002.993] "pmu-board" doesn't exist, creating
[0002.999] Updated board info to DTB
[0003.003] "display-board" doesn't exist, creating
[0003.008] Updated board info to DTB
[0003.012] "reset" doesn't exist, creating
[0003.016] Updated reset info to DTB
[0003.020] display_console_ioctl: No display init
[0003.024] display_console_ioctl: No display init
[0003.029] display_console_ioctl: No display init
[0003.033] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt
[0003.068] DTB cmdline: kmemleak=on earlycon=uart8250,mmio32,0x70006000
[0003.075] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0003.091] Updated bootarg info to DTB
[0003.095] Adding uuid 0000000164449587240000000e018300 to DT
[0003.100] Adding eks info 0 to DT
[0003.106] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0003.112] Updated memory info to DTB
[0003.120] set vdd_core voltage to 1075 mv
[0003.124] setting 'vdd-core' regulator to 1075000 micro volts
[0003.129] Found secure-pmc; disable BPMP
U-Boot 2020.04-g46e4604c78 (Jul 26 2021 - 12:09:42 -0700)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM: 4 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
582 bytes read in 38 ms (14.6 KiB/s)
p2771-0000 eMMC boot options
1: primary kernel
2: recovery kernel
Enter choice:
