Hi, all:
I had a fresh installation* of cudatookit 2.2 and cudasdk 2-2.21 on a MacBook Pro with Mac OS X 10.5.8. Everything went ok until I run bandwidthTest, which gives an error
“udaSafeCall() Runtime API error in file <bandwidthTest.cu>, line 667 : no CUDA-capable device is available.”
I have /usr/local/cuda/bin added into path, and /usr/local/cuda/lib added into DYLD_LIBRARY_PATH .
I post below the output of deviceQuery and bandwidthTest :
[dh11:bin/darwin/release] % ./deviceQuery
CUDA Device Query (Runtime API) version (CUDART static linking)
There is no device supporting CUDA.
Device 0: “Device Emulation (CPU)”
CUDA Capability Major revision number: 9999
CUDA Capability Minor revision number: 9999
Total amount of global memory: 4294967295 bytes
Number of multiprocessors: 16
Number of cores: 128
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 1
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.35 GHz
Concurrent copy and execution: No
Run time limit on kernels: No
Integrated: Yes
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple host threads can use this device simultaneously)
Test PASSED
Press ENTER to exit…
[dh11:bin/darwin/release] % ./bandwidthTest
Running on…
device 0:Device Emulation (CPU)
Quick Mode
Host to Device Bandwidth for Pageable memory
cudaSafeCall() Runtime API error in file <bandwidthTest.cu>, line 667 : no CUDA-capable device is available.
Could anybody give an advice please?
*Actually I first installed cudatookit and cuda sdk 2.3 then later uninstalled it by deleting /usr/local/cuda. I then installed cudatookit and sdk 2.2. The error message I got are the same in both installations.
