Hi All,
I have a simple code that I want to check its bank conflicts using CUT_BANK_CHECKER.
The following is the definitions:
typedef struct type {
float x;
float y;
}type2;
#define S(i) CUT_BANK_CHECKER(((type2*)&s[0]), i)
Bellow is the snippet of code that I’m writing to the shared memory:
__global__ void
test (float* C, float* A)
__shared__ type2 s[64];
type2 data;
data.x = 3.1*A[tid];
data.y = 5.5*A[tid];
S(tid) = data;
s[tid].x = ty + s[tid].y;
s[tid].y = tx + s[tid].x;
C[tid] = s[tid].x+2*s[tid].y;
Based on the cuda manual, this should have bank conflicts. But, I get 0 bank conflicts results from the CUT_BANK_CHECKER.
Am I missing anything here?
