Hi all-
I’m a little confused about some of the bank-conflict resolving strategies, and was hoping someone could clarify…
It is often stated that a common access pattern is:
shared char shared[32];
char data = shared[BaseIndex + 4 * tid];
Let’s assume I have 32 threads per block and (just for this example) only 1 block per grid. I understand how the stride of 4 is used to make sure the threads are accessing different banks, since 4 8-bit char’s belong to the same 32-bit word (and therefore the same bank). My question is: is it safe to assume that BaseIndex == 0 always? If not, how does one go about making sure that BaseIndex corresponds to a properly-aligned multiple of the word size?
Thanks in advance for any input/advice/suggestions!
In this particular case, you’ll get no bank conflicts no matter what baseIndex is. The key is to have every thread read from a different bank, and it doesn’t matter if thread 0 reads from bank 0 or bank 11 or whatever as long as no other thread also reads that bank. (exception, with broadcast words, but that’s a bonus.)
What you’re kind of worried about is a different but slightly similar sounding issue with base address alignment of coalesced global read requirements on old G80 hardware. That doesn’t apply to your shared memory access question.
