basic kernel failure why?
this simple example is not working, im testing 2D grids,with 1D blocks inside. im not sure what does it mean with “Invalid Argument”
Cuda error: Kernel execution failed in file '/home/neoideo/Galaxia/meshEditor/src/myCudaCalls.cu' in line 175 : invalid argument.
and code
//! Detectar Colisiones
void myCudaDetectarColisionesShared(){
	dim3 dimBlock(MYCUDA_BLOCK_SIZE_COLISSION_i);
	dim3 dimGrid((numCaras+MYCUDA_BLOCK_SIZE_COLISSION_j) / MYCUDA_BLOCK_SIZE_COLISSION_j, (numCaras+MYCUDA_BLOCK_SIZE_COLISSION_i)/ dimBlock.x );
	cudaThreadSynchronize();
	kernelDetectarInterseccionesShared<<< dimGrid, dimBlock >>>();
	CUT_CHECK_ERROR("Kernel execution failed");
#define MYCUDA_BLOCK_SIZE_COLISSION_i 32
#define MYCUDA_BLOCK_SIZE_COLISSION_j 10
__global__ void kernelDetectarInterseccionesShared(){
	int i = blockIdx.y * blockDim.x + threadIdx.x;
	if( i > 10 ){
		int a = i+1;
	return;
