Batch processing in tracker not working
Hardware Platform (Jetson / GPU) GPU RTX 2060
• DeepStream Version 5.0
• TensorRT Version 7.1
• NVIDIA GPU Driver Version (valid for GPU only) 450
I have succesfully implemented the nvtracker with a single stream process function as below
NvMOTStatus NvMOT_Process(NvMOTContextHandle contextHandle,
NvMOTProcessParams *pParams,
NvMOTTrackedObjBatch *pTrackedObjectsBatch)
NvMOTFrame *fr = pParams->frameList;
fr->timeStamp = time(0);
std::cerr<<“fr->timeStamp:”<timeStamp<<std::endl;
NvMOTObjToTrackList det_obj = fr->objectsIn;
NvMOTObjToTrack *obj_to_trk = det_obj.list;
int filled = det_obj.numFilled;
NvMOTTrackedObjBatch motOutputObjectsMeta;
NvMOTTrackedObjList
tObjList = &pTrackedObjectsBatch->list[0];
for(uint streamInd = 0; streamInd < filled; streamInd++)
	TrackingBox tb;
	tb.frame= sort.frame_count+1;
	tObjList->list[streamInd] = NvMOTTrackedObj{};
	tObjList->list[streamInd].classId = obj_to_trk[streamInd].classId;
	tObjList->list[streamInd].confidence = obj_to_trk[streamInd].confidence;
	tObjList->list[streamInd].age = 0;
	tb.id = -1;
	tb.score =  obj_to_trk[streamInd].confidence;
	tb.box = Rect_<float>(Point_<float>(obj_to_trk[streamInd].bbox.x, obj_to_trk[streamInd].bbox.y), Point_<float>(obj_to_trk[streamInd].bbox.x + obj_to_trk[streamInd].bbox.width, obj_to_trk[streamInd].bbox.y + obj_to_trk[streamInd].bbox.height));
	sort.detData.push_back(tb);
	//std:cerr<<obj_to_trk[streamInd].pPreservedData<<endl;
/*Passing the ids, bboxes and confidences to tracked output data*/
uint streamInd = 0;
for (auto tb : sort.update())
	tObjList->list[streamInd].trackingId = tb.id;
	tObjList->list[streamInd].bbox.x = tb.box.x;
	tObjList->list[streamInd].bbox.y = tb.box.y;
	tObjList->list[streamInd].bbox.height = tb.box.height;
	tObjList->list[streamInd].bbox.width = tb.box.width;
	tObjList->numFilled =  filled;
	tObjList->valid = true;
	if(tObjList->valid == false)
		continue;
	uint32_t streamID = tObjList->streamID;
	if(tObjList->numFilled > 0)
		for(uint i=0; i<tObjList->numFilled; ++i)
			NvMOTTrackedObj *tObj = &tObjList->list[i];
	streamInd++;
return NvMOTStatus_OK;
but for batch processing with more than 1 stream I am not getting continous bboxes My code is like below
NvMOTObjToTrackList det_obj[maxstreams];
NvMOTObjToTrack obj_to_trk[maxstreams];
int filled[maxstreams];
NvMOTTrackedObjList
tObjList[maxstreams];
NvMOTTrackedObj *tObj[maxstreams];
vector detData_i;
vector<vector> detstreamData;
vector<vector> tempData;
vector trkData;
/*Obtaining the bboxes and confidences from detected output data*/
for(uint streamid = 0; streamid < maxstreams; streamid++ )
	det_obj[streamid] = fr[streamid].objectsIn;
	obj_to_trk[streamid] = det_obj[streamid].list;
	filled[streamid] = det_obj[streamid].numFilled;
	tObjList[streamid] = &pTrackedObjectsBatch->list[streamid];
int maxfilled = filled[0];
	if(filled[streamid]>maxfilled)
		maxfilled = filled[streamid];
	for(uint streamInd = 0; streamInd < filled[streamid]; streamInd++)
		TrackingBox tb;
		tb.frame= fi+1;
		tObjList[streamid]->list[streamInd] = NvMOTTrackedObj{};
		tObjList[streamid]->list[streamInd].classId = obj_to_trk[streamid][streamInd].classId;
		tObjList[streamid]->list[streamInd].confidence = obj_to_trk[streamid][streamInd].confidence;
		tObjList[streamid]->list[streamInd].age = 0;
		tb.id = streamInd;
		tb.score =  obj_to_trk[streamid][streamInd].confidence;
		tb.box = Rect_<float>(Point_<float>(obj_to_trk[streamid][streamInd].bbox.x, obj_to_trk[streamid][streamInd].bbox.y), Point_<float>(obj_to_trk[streamid][streamInd].bbox.x + obj_to_trk[streamid][streamInd].bbox.width, obj_to_trk[streamid][streamInd].bbox.y + obj_to_trk[streamid][streamInd].bbox.height));
		tb.obj_num = streamInd;
		tb.batchID = fr[streamid].streamID;
		detData_i.push_back(tb);
vector<TrackingBox> tempVec;
if(detData_i.size()!=0)
		for (auto tb : detData_i){
			if (tb.batchID == fr[streamid].streamID)
				tempVec.push_back(tb);
		detstreamData.push_back(tempVec);
		tempVec.clear();
	batchtracker.obj.id=1;
	uint streamInd = 0;
		for (auto tb : batchtracker.update(detstreamData[streamid],streamid))
			batchtracker.old_id.push_back(tb.id);
			for (uint k = 0;k < batchtracker.j; k++){
				if(batchtracker.old_id[k] == tb.id){
					batchtracker.obj.id = batchtracker.new_id[k];
					batchtracker.flag=1;
			if(!batchtracker.flag){
				if(batchtracker.j!=0){
					batchtracker.m=batchtracker.m+1;
					batchtracker.obj.id = batchtracker.m+1;
			batchtracker.new_id.push_back(batchtracker.obj.id);
			batchtracker.j++;
			batchtracker.flag=0;
			//tb.id = batchtracker.obj.id;
			trkData.push_back(tb);
			streamInd++;
			cerr<<"tb.id"<<tb.id<<"tb.streamid"<<tb.batchID<<endl;
		streamInd = 0;
	for(uint streamInd = 0; streamInd < maxfilled; streamInd++)
		uint streamid = 0;
		for (auto tb : trkData){
			if ((tb.batchID == fr[streamid].streamID) && (tb.obj_num == streamInd) )
				tObjList[streamid]->list[streamInd].trackingId = tb.id;
				tObjList[streamid]->list[streamInd].bbox.x = tb.box.x;
				tObjList[streamid]->list[streamInd].bbox.y = tb.box.y;
				tObjList[streamid]->list[streamInd].bbox.height = tb.box.height;
				tObjList[streamid]->list[streamInd].bbox.width = tb.box.width;
				tObjList[streamid]->numFilled =  filled[streamid];
				tObjList[streamid]->valid = true;
				if(tObjList[streamid]->valid == false)
					continue;
				streamid++;
fi++;
Hi Please some one respond
Sorry for the late response, we will investigate this issue to have update soon. Thanks
What does this mean?
I am getting cross talks if one stream ends in the batch processing mode between other streams
I have the same issue that is mentioned in this post but I couldnt understand how he resolved it . Can you please give me an example
We don’t have such sample. Please check if the tracked object metadata in NvMOTTrackedObjBatch are all correct in terms of StreamID.
