Batch size
I have a few questions about batch size:
  • Is there a point (performance, for example) to a batch size > 1 for a single camera source? Has this been benchmarked?
  • I'm currently planning on parsing the detection metadata with a probe attached to a fakesink pad and this function here:
  • // many thanks to NVIDIA's test1_app for showing me how to do this right
    GstPadProbeReturn on_batch(GstPad* pad,
                               GstPadProbeInfo* info,
                               gpointer u_data) {
      // get batched metadata:
      NvDsBatchMeta* batch = gst_buffer_get_nvds_batch_meta((GstBuffer*)info->data);
      NvDsMetaList* frames = NULL;
      NvDsFrameMeta* frame = NULL;
      NvDsMetaList* objects = NULL;
      NvDsObjectMeta* object = NULL;
      // for frame in batch.frame_meta_list:
      for (frames = batch->frame_meta_list; frames != NULL; frames = frames->next) {
        frame = (NvDsFrameMeta*)(frames->data);
        // for object in frame.obj_meta_list:
        for (objects = frame->obj_meta_list; objects != NULL;
             objects = objects->next) {
          object = (NvDsObjectMeta*)(objects->data);
          if (object->class_id == BIRB_ID) {
            dump_bbox(frame->frame_num, &object->rect_params);
    “dump_bbox” is currently set to print to stdio, but I will soon send the data to be dumped to sidecar file in batches instead of printed. My question is: is there a huge disadvantage to doing what I want this way as opposed to using nvmsgconv?
    Sorry that we don’t have benchmark results of batchsize with deepstream.
    But here is the profiling data with TensorRT cross batchsize.
    [url]https://developer.nvidia.com/embedded/jetson-agx-xavier-dl-inference-benchmarks[/url]
    2.
    Suppose not.
    @mdegans
    Is there a point (performance, for example) to a batch size > 1 for a single camera source? Has this been benchmarked? >> We have not benchmarked such a use-case, however if you are trying this approach i would suggest these changes.
    Temporal batching for a single camera source makes sense only when your camera FPS is lower than 30. To do so, you can increase the “batch-timeout” property on the streammux to wait until you have the required number of frames in batch. Also make sure to set your streammux and pgie batch-size are the same. Keep in mind with this approach the display on the sink wont be smooth when compared to non-batched pipeline.
    Thanks for the suggestion. That’s very useful since the two branches of my pipeline (encoder and inference) after my tee don’t need to resync and I want to write the metadata in chunks. I will experiment with batches and make sure all my elements in my inference branch use the same batch size.
