Battery charger for TX1
Hi everybody!
I would like to know if someone have a reference to communicate for battery charger suitable with the TX1 (wich switch to battery when disconnected and charge it when connected)?
I have read the documentation, the way to connect it with the i2c port and so on, but i can’t find an approriate device for LiPo 3S for example.
Thank you!
Hi Gabygab,
We provide the design guidelines and an example for a battery powered NVIDIA Jetson TX1 system with a charger.
Please find the Jetson TX1 Module Battery and Charger Design Guide from download center:
http://developer.nvidia.com/embedded/dlc/jetson-tx1-module-battery-and-charger-design-guide
how can i configure intterupts in dts file
what’s interrupts in dts file
@tserensodnom
It’s should be relative to the charger IC driver. Could you check with the charger ic vendor.
