What happens when I pull down BATTERY_OC#? Is it just a warning? Clocks throttle? Power off?
Thank you
Thank you
Hi eric,
Are you talking about charger design guideline? Pull down this signal will generate a interrupt to system and then throttle performance to reduce current.
Yes I was talking about the charger design guidelines thank you.
