Battery Over Current Limit Hit warning message spamming syslog
Hey, I am using a custom TX1 carrier board that is constantly printing this message to syslog: WARNING - Battery Over Current Limit hit, please refer to the Jetson Power management application note
It only prints the message when put under high loads. When the board is idle, the message doesn’t appear. We do have batteries in our device, but the message appears when they are both plugged in and unplugged.
I have found the section of the device tree file, tegra210-jetson-tx1-p2597-2180-a02-devkit-24x7.dts, that this warning message comes from, which is sysedp_reactive_capping@3 (very last section).
I looked up sysedp_reactive_capping and it refers to some battery management system that I am not familiar with.
Does anyone know the details about this section of the dts file?
Is there any downside to removing this section of the dts file?
I tried removing it and didn’t notice any differences aside from the message disappearing, but I imagine it is a bad idea to remove something from here without fully understanding what it’s doing.
Hi mlf,
This might be caused by critical current limit setting of VDD_IN of power monitor.
The power monitor accepts the configuration data from Device Tree source file resides at kernel/arch/arm64/boot/dts/tegra210-platforms/tegra210-jetson-cv-powermon-p2180-1000-a00.dtsi
i2c@7000c400 {
ina3221x: ina3221x@40 {
compatible = “ti,ina3221x”;
reg = <0x40>;
ti,trigger-config = <0x7003>;
ti,continuous-config = <0x7607>;
ti,enable-forced-continuous;
#io-channel-cells = <1>;
#address-cells = <1>;
#size-cells = <0>;
status = “disabled”;
        channel@0 {
            reg = <0x0>;
            ti,rail-name = "VDD_IN";
            ti,shunt-resistor-mohm = <20>;
            ti,current-critical-limit-ma = <2105>;
            shunt-volt-offset-uv = <&p2180_shuntv_offset>;
Where,
The current-critical-limit-ma of channel 0 (VDD_IN) is calculated from system EDP limit and input voltage of Jetson-CVM.
The critical current limit = System EDP limit / VDD_IN voltage
The system EDP limit for the Jetson TX1 module, as part of the Jetson TX1 Developer Kit, is defined at kernel/arch/arm64/boot/dts/tegra210-jetson-cv-base-p2597-2180-a00.dts
sysedp {
compatible = “nvidia,tegra124-sysedp”;
nvidia,margin = <0>;
nvidia,min_budget = <0>;
nvidia,initial_budget = <40000>;
Critical current limit for 19V VDD_IN = 40,000 / 19 => 2105mA
The system integrator must configure the correct critical current limit based on moduleJetson-CVM input voltage.
For example, the critical current limited for 8V VDD_IN is calculated as below.
Critical current limit for 8V VDD_IN = 40,000 / 8 => 5000mA
Trumany,
Is this warning meaningful at all if there is no power monitor connected to the TX1 PM I2C port
(On module pins A6 and B6)?
What if there is no INA3221 on my TX1 carrier board?
How can this kernel message be silenced?
This warning is generated by power monitor in module not on carrier board, it can not be silenced unless follow above dtsi change.
HiTrumary,
What’s the policy if the over current happened?
Could I check the status in syslog? Or It will show the same message as mlft described?
If the over current happen, system performance will be throttled so as to reduce power consumption. And then will show same warning message as mlft described.
Hi Trumany,
How about another current monitor circuit such like ina3221 which address is 0x42 for VDD_MUX/VDD_5V_IO_SYS/VDD_3V3_SYS and ina3221 which address is 0x42 for VDD_3V3_IO/VDD_1V8_IO/VDD_M2_IN ?
If the over current happen from the two current monitor, could we see any message and is the policy is also to reduce power consumption?
Yes, they are for power monitor of their corresponding rail in case possible need. And this 2 INAs will not report interrupt to system.
Hi Trumany,
Thanks for your information.
Some questions to confirm.
  • According to your response "this 2 INAs will not report interrupt to system", did you mean we couldn't detect this condition from the warning message the same with above discussion if the over current happened.
  • When over current happen in this two INAs, what's the action which TX1 will make?
  • We have one issue that the TX1 module crashed(we could no longer connect to TX1 in remote method such as SSH), and the relative power control was disabled at the same time by TX1, is this an over current case?
Assume we are talking about the dev kit, not about your own designed carrier board.
  1. Yes, usually you can take this two INAs as no use because their interrupt pins are unconnected, you can see this in schematic.
  2. Generally these rails will not over current unless some components damaged, the INA in module is to monitor GPU/CPU rails which are often dynamic with workload.
  3. looks not like a over current case.
Hi Trumany,
According to point 2 you mentioned that “these rails will not over current unless some components damaged”, Is this because of the current limitation setting, I could check the value via sysfs nodes refer to this link( https://devtalk.nvidia.com/default/topic/950341/jetson-tx1/jetson-tx1-ina226-power-monitor-with-i2c-interface-/post/4998393/#4998393), and the setting for channel-0/channel-1/channel-2 are 8190/32760/16380 respectively? It seems that it’s not easy to touch the limitation especially the channel-1 and channel-2.
Hi Trumany,
Another question.
I could see the current limit setting of 0x40/0x42/0x43 via sysfs nodes, and 0x40 setting in device tree file, but couldn’t find the 0x42/0x43 setting at the same device tree, could I modify the 0x42/0x43 setting? If yes, which device tree file could I find?
Thanks very much
You can refer to this topic: https://devtalk.nvidia.com/default/topic/950341/jetson-tx1/jetson-tx1-ina226-power-monitor-with-i2c-interface-/post/4998393/#4998393
Please note the INAs on carrier board are just for reading the current/voltage value of the rails, no hardware interrupt will generate even if the threshold reached as the pins are unconnected.
Hi Ray0420,
Please find kernel/arch/arm64/boot/dts/tegra210-platforms/tegra210-jetson-cv-powermon-p2597.dtsi for them.
Hi vickyy & Trumany
Thanks very much
Hi @Trumany,
As I’m seeing the status of the monitoring chip id is in disable state.
reg = <0x40>;
#size-cells = <0>;
I would like to know, how this will get integrated and will update the driver?
Hi, it is only enabled on the module revision is 300 or greater, please refer to this : https://devtalk.nvidia.com/default/topic/950341/jetson-tx1/jetson-tx1-ina226-power-monitor-with-i2c-interface-/post/4998393/#4998393
