Battery powering D315 carrying board. What should I do?
This board is the first board I have seen that comes with 54V barrel jack. I am a mechanical angineer, so my electrical know-how is above a bit, tiny bit, average. As far as I see, barrel jack only accepts 54V, but finding a step up regulator that can boost to that voltage might be a problem. Besides I plan to use 11.1V lipo and boost it somewhere around 24V. I plan to power the board trough the ATX 4P connection, which accepts 12 to 54V. I will connect the 2 positive terminals of this connector to the 24V output, and 2 ground to the ground of the step up regulator. Is this plan good? Is there any other suggestion you can make that would make things a bit easier?
Hi, please check with carrier board vendor for this.
