Hi ShaneCCC,
We configured our sensor to discontinuous mode which we confirmed via scope.
We changed the dts to have discontinuous_clk=“yes” and also made the tegracam_ctrl_ops callback functions of the sensor driver to be dummy (ie) return 0.
But with this settings, the v4l2 capture returns frame discard error.
v4l2-ctl -d /dev/video2 --set-fmt-video=width=1472,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test_image.bayer
Blockquote
dmesg
[ 126.376885] tegra194-vi5 15c10000.vi: corr_err: discarding frame : 1 & Sequence : 0 from stream : 4, flags: 0, err_data: 131072 status: 14 sof_time : 136810883232 eof_time : 4378083860480
[ 126.381453] tegra194-vi5 15c10000.vi: corr_err: discarding frame : 2 & Sequence : 1 from stream : 4, flags: 0, err_data: 131072 status: 14 sof_time : 136815513248 eof_time : 4378232022016
[ 126.386096] tegra194-vi5 15c10000.vi: corr_err: discarding frame : 1 & Sequence : 2 from stream : 4, flags: 0, err_data: 131072 status: 14 sof_time : 136820143232 eof_time : 4378380180480
[ 126.390029] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[ 126.390808] tegra194-vi5 15c10000.vi: corr_err: discarding frame : 2 & Sequence : 3 from stream : 4, flags: 0, err_data: 131072 status: 14 sof_time : 136824773216 eof_time : 4378528339968
[ 126.395342] tegra194-vi5 15c10000.vi: corr_err: discarding frame : 1 & Sequence : 4 from stream : 4, flags: 0, err_data: 131072 status: 14 sof_time : 136829403232 eof_time : 4378676500480
[ 126.399987] tegra194-vi5 15c10000.vi: corr_err: discarding frame : 2 & Sequence : 5 from stream : 4, flags: 0, err_data: 131072 status: 14 sof_time : 136834033216 eof_time : 4378824659968
[ 126.404662] tegra194-vi5 15c10000.vi: corr_err: discarding frame : 1 & Sequence : 6 from stream : 4, flags: 0, err_data: 131072 status: 14 sof_time : 136838663232 eof_time : 4378972819456
[ 126.409244] tegra194-vi5 15c10000.vi: corr_err: discarding frame : 2 & Sequence : 7 from stream : 4, flags: 0, err_data: 131072 status: 14 sof_time : 136843293184 eof_time : 4379120978944
[ 126.420918] tegra194-vi5 15c10000.vi: corr_err: discarding frame : 1 & Sequence : 8 from stream : 4, flags: 0, err_data: 131072 status: 14 sof_time : 136847923200 eof_time : 4379269139456
[ 126.437464] tegra194-vi5 15c10000.vi: corr_err: discarding frame : 2 & Sequence : 9 from stream : 4, flags: 0, err_data: 131072 status: 14 sof_time : 136852553184 eof_time : 4379417297920
[ 126.454620] tegra194-vi5 15c10000.vi: corr_err: discarding frame : 1 & Sequence : 10 from stream : 4, flags: 0, err_data: 131072 status: 14 sof_time : 136857183200 eof_time : 4379565459456
[ 126.471539] tegra194-vi5 15c10000.vi: corr_err: discarding frame : 2 & Sequence : 11 from stream : 4, flags: 0, err_data: 131072 status: 14 sof_time : 136861813184 eof_time : 4379713619968
[ 126.488441] tegra194-vi5 15c10000.vi: corr_err: discarding frame : 2 & Sequence : 12 from stream : 4, flags: 0, err_data: 131072 status: 14 sof_time : 136880333152 eof_time : 4380306257920
[ 126.505023] tegra194-vi5 15c10000.vi: corr_err: discarding frame : 1 & Sequence : 13 from stream : 4, flags: 0, err_data: 131072 status: 14 sof_time : 136894223136 eof_time : 4380750738432
[ 126.521913] tegra194-vi5 15c10000.vi: corr_err: discarding frame : 1 & Sequence : 14 from stream : 4, flags: 0, err_data: 131072 status: 14 sof_time : 136912743104 eof_time : 4381343376384
The libargus has the same error as before, (no reply from camera processor)
Blockquote
gst-launch-1.0 nvarguscamerasrc sensor-id=2 ! videoconvert ! autovideosink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1472 x 1080 FR = 226.580010 fps Duration = 4413452 ; Analog Gain range min 0.000000, max 3.000000; Exposure Range min 1000, max 100000000;
GST_ARGUS: 1472 x 540 FR = 226.580010 fps Duration = 4413452 ; Analog Gain range min 0.000000, max 3.000000; Exposure Range min 1000, max 100000000;
GST_ARGUS: Running with following settings:
Camera index = 2
Camera mode = 0
Output Stream W = 1472 H = 1080
seconds to Run = 0
Frame Rate = 226.580010
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
Blockquote dmesg
dmesg
[ 188.879979] imx219 9-0010: imx219_open:
[ 188.880132] imx219 10-0010: imx219_open:
[ 188.880306] imx219 11-0010: imx219_open:
[ 189.345870] [RCE] WARNING: t194/isp5.c:901 [config_channel] “All error notifications not enabled: correctable=0x00 uncorrectable=0x00”
[ 190.297876] [RCE] vi5_hwinit: firmware CL2018101701 protocol version 2.2
[ 192.117769] tegra194-vi5 15c10000.vi: vi_capture_status : no reply from camera processor
[ 192.117965] tegra194-vi5 15c10000.vi: vi capture get status failed
[ 192.118544] fence timeout on [ffffffc1ec68fa80] after 1500ms
[ 192.118555] name=[nvhost_sync:31], current value=0 waiting value=1
[ 192.118565] ---- mlocks ----
[ 192.118616] ---- syncpts ----
[ 192.118659] id 22 (gv11b_510_user) min 27 max 0 refs 1 (previous client : )
[ 192.118681] id 34 (gv11b_506) min 3 max 3 refs 1 (previous client : )
[ 192.118688] id 35 (gv11b_505) min 4 max 4 refs 1 (previous client : )
[ 192.118695] id 36 (gv11b_504) min 3 max 3 refs 1 (previous client : )
[ 192.118702] id 37 (gv11b_503) min 3 max 3 refs 1 (previous client : )
[ 192.118738] id 38 (gv11b_502) min 3 max 3 refs 1 (previous client : )
[ 192.119593] ---- channels ----
[ 192.119628]
channel 2 - 15820000.se
[ 192.119634] NvHost basic channel registers:
[ 192.119642] CMDFIFO_STAT_0: 00002040
[ 192.119648] CMDFIFO_RDATA_0: 06041055
[ 192.119659] CMDP_OFFSET_0: 00000000
[ 192.119666] CMDP_CLASS_0: 00000000
[ 192.119673] CHANNELSTAT_0: 00000000
[ 192.119678] The CDMA sync queue is empty.
[ 192.119690]
channel 3 - 15830000.se
[ 192.119695] NvHost basic channel registers:
[ 192.119702] CMDFIFO_STAT_0: 00002040
[ 192.119708] CMDFIFO_RDATA_0: c1000010
[ 192.119717] CMDP_OFFSET_0: 00000000
[ 192.119723] CMDP_CLASS_0: 00000000
[ 192.119729] CHANNELSTAT_0: 00000000
[ 192.119734] The CDMA sync queue is empty.
[ 192.119745]
channel 4 - 15840000.se
[ 192.119750] NvHost basic channel registers:
[ 192.119756] CMDFIFO_STAT_0: 00002040
[ 192.119762] CMDFIFO_RDATA_0: 01282400
[ 192.119770] CMDP_OFFSET_0: 00000000
[ 192.119776] CMDP_CLASS_0: 00000000
[ 192.119781] CHANNELSTAT_0: 00000000
[ 192.119786] The CDMA sync queue is empty.
[ 192.119800]
---- host general irq ----
[ 192.119807] sync_intc0mask = 0x00000001
[ 192.119814] sync_intmask = 0x50000003
[ 192.119818]
---- host syncpt irq mask ----
[ 192.119823]
---- host syncpt irq status ----
[ 192.119831] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 192.119838] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 192.119845] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 192.119852] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 192.119859] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 192.119865] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 192.119872] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 192.119879] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 192.119885] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 192.119892] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 192.119898] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 192.119904] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 192.119911] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 192.119917] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 192.119923] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 192.119929] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 192.119935] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 192.119942] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 192.119948] syncpt_thresh_cpu0_int_status(18) = 0x00000000
[ 192.119954] syncpt_thresh_cpu0_int_status(19) = 0x00000000
[ 192.119960] syncpt_thresh_cpu0_int_status(20) = 0x00000000
[ 192.119967] syncpt_thresh_cpu0_int_status(21) = 0x00000000
[ 193.621767] fence timeout on [ffffffc1ec32f240] after 1500ms
[ 193.621774] tegra194-vi5 15c10000.vi: vi_capture_status : no reply from camera processor
[ 193.621791] tegra194-vi5 15c10000.vi: vi capture get status failed
[ 193.621987] fence timeout on [ffffffc1ec32ff00] after 1500ms
[ 193.621998] name=[nvhost_sync:31], current value=0 waiting value=10
[ 193.622006] ---- mlocks ----
[ 193.622052] ---- syncpts ----
[ 193.622095] id 22 (gv11b_510_user) min 27 max 0 refs 1 (previous client : )
[ 193.622115] id 34 (gv11b_506) min 3 max 3 refs 1 (previous client : )
[ 193.622135] name=[nvhost_sync:31], current value=0 waiting value=15
[ 193.622140] id 35 (gv11b_505) min 4 max 4 refs 1 (previous client : )
[ 193.622146] id 36 (gv11b_504) min 3 max 3 refs 1 (previous client : )
[ 193.622150] ---- mlocks ----
[ 193.622158] id 37 (gv11b_503) min 3 max 3 refs 1 (previous client : )
[ 193.622167] id 38 (gv11b_502) min 3 max 3 refs 1 (previous client : )
[ 193.622203] ---- syncpts ----
[ 193.623053] ---- channels ----
[ 193.623089] id 22 (gv11b_510_user) min 27 max 0 refs 1 (previous client : )
[ 193.623092]
[ 193.623097] NvHost basic channel registers:
[ 193.623109] CMDFIFO_STAT_0: 00002040
[ 193.623116] CMDFIFO_RDATA_0: 06041055
[ 193.623122] id 34 (gv11b_506) min 3 max 3 refs 1 (previous client : )
[ 193.623127] CMDP_OFFSET_0: 00000000
[ 193.623140] id 35 (gv11b_505) min 4 max 4 refs 1 (previous client : )
[ 193.623142] CMDP_CLASS_0: 00000000
[ 193.623148] CHANNELSTAT_0: 00000000
[ 193.623152] id 36 (gv11b_504) min 3 max 3 refs 1 (previous client : )
[ 193.623158] id 37 (gv11b_503) min 3 max 3 refs 1 (previous client : )
[ 193.623160] The CDMA sync queue is empty.
[ 193.623172] id 38 (gv11b_502) min 3 max 3 refs 1 (previous client : )
[ 193.623175]
[ 193.623179] NvHost basic channel registers:
[ 193.623188] CMDFIFO_STAT_0: 00002040
[ 193.623195] CMDFIFO_RDATA_0: c1000010
[ 193.623203] CMDP_OFFSET_0: 00000000
[ 193.623209] CMDP_CLASS_0: 00000000
[ 193.623215] CHANNELSTAT_0: 00000000
[ 193.623226] The CDMA sync queue is empty.
[ 193.623238]
[ 193.623244] NvHost basic channel registers:
[ 193.623250] CMDFIFO_STAT_0: 00002040
[ 193.623256] CMDFIFO_RDATA_0: 01282400
[ 193.623264] CMDP_OFFSET_0: 00000000
[ 193.623270] CMDP_CLASS_0: 00000000
[ 193.623275] CHANNELSTAT_0: 00000000
[ 193.623280] The CDMA sync queue is empty.
[ 193.623295]
[ 193.623301] sync_intc0mask = 0x00000001
[ 193.623308] sync_intmask = 0x50000003
[ 193.623313]
[ 193.623317]
[ 193.623325] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 193.623332] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 193.623339] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 193.623346] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 193.623353] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 193.623360] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 193.623367] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 193.623374] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 193.623380] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 193.623386] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 193.623393] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 193.623399] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 193.623406] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 193.623413] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 193.623419] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 193.623425] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 193.623431] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 193.623437] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 193.623443] syncpt_thresh_cpu0_int_status(18) = 0x00000000
[ 193.623450] syncpt_thresh_cpu0_int_status(19) = 0x00000000
[ 193.623456] syncpt_thresh_cpu0_int_status(20) = 0x00000000
[ 193.623462] syncpt_thresh_cpu0_int_status(21) = 0x00000000
[ 193.624066] ---- channels ----
[ 193.624100]
[ 193.624105] NvHost basic channel registers:
[ 193.624113] CMDFIFO_STAT_0: 00002040
[ 193.624120] CMDFIFO_RDATA_0: 06041055
[ 193.624130] CMDP_OFFSET_0: 00000000
[ 193.624137] CMDP_CLASS_0: 00000000
[ 193.624144] CHANNELSTAT_0: 00000000
[ 193.624149] The CDMA sync queue is empty.
[ 193.624162]
[ 193.624167] NvHost basic channel registers:
[ 193.624174] CMDFIFO_STAT_0: 00002040
[ 193.624181] CMDFIFO_RDATA_0: c1000010
[ 193.624190] CMDP_OFFSET_0: 00000000
[ 193.624196] CMDP_CLASS_0: 00000000
[ 193.624202] CHANNELSTAT_0: 00000000
[ 193.624207] The CDMA sync queue is empty.
[ 193.624219]
[ 193.624224] NvHost basic channel registers:
[ 193.624230] CMDFIFO_STAT_0: 00002040
[ 193.624237] CMDFIFO_RDATA_0: 01282400
[ 193.624244] CMDP_OFFSET_0: 00000000
[ 193.624250] CMDP_CLASS_0: 00000000
[ 193.624256] CHANNELSTAT_0: 00000000
[ 193.624261] The CDMA sync queue is empty.
[ 193.624276] ---- host general irq ----
[ 193.624283] sync_intc0mask = 0x00000001
[ 193.624289] sync_intmask = 0x50000003
[ 193.624294]
[ 193.624299]
[ 193.624307] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 193.624314] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 193.624321] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 193.624328] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 193.624335] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 193.624342] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 193.624349] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 193.624357] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 193.624363] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 193.624369] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 193.624376] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 193.624382] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 193.624389] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 193.624395] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 193.624401] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 193.624408] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 193.624414] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 193.624420] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 193.624427] syncpt_thresh_cpu0_int_status(18) = 0x00000000
[ 193.624433] syncpt_thresh_cpu0_int_status(19) = 0x00000000
[ 193.624440] syncpt_thresh_cpu0_int_status(20) = 0x00000000
[ 193.624446] syncpt_thresh_cpu0_int_status(21) = 0x00000000
[ 195.157726] fence timeout on [ffffffc1ec32ff00] after 1500ms
[ 195.157742] tegra194-vi5 15c10000.vi: vi_capture_status : no reply from camera processor
[ 195.157747] name=[nvhost_sync:31], current value=0 waiting value=16
[ 195.157762] ---- mlocks ----
[ 195.157837] ---- syncpts ----
[ 195.157945] tegra194-vi5 15c10000.vi: vi capture get status failed
[ 195.157956] id 22 (gv11b_510_user) min 27 max 0 refs 1 (previous client : )
[ 195.157976] id 34 (gv11b_506) min 3 max 3 refs 1 (previous client : )
[ 195.157981] id 35 (gv11b_505) min 4 max 4 refs 1 (previous client : )
[ 195.157986] id 36 (gv11b_504) min 3 max 3 refs 1 (previous client : )
[ 195.157997] id 37 (gv11b_503) min 3 max 3 refs 1 (previous client : )
[ 195.158002] id 38 (gv11b_502) min 3 max 3 refs 1 (previous client : )
[ 195.158890] ---- channels ----
[ 195.158926]
[ 195.158931] NvHost basic channel registers:
[ 195.158940] CMDFIFO_STAT_0: 00002040
[ 195.158946] CMDFIFO_RDATA_0: 06041055
[ 195.158956] CMDP_OFFSET_0: 00000000
[ 195.158962] CMDP_CLASS_0: 00000000
[ 195.158969] CHANNELSTAT_0: 00000000
[ 195.158974] The CDMA sync queue is empty.
[ 195.158986]
[ 195.158991] NvHost basic channel registers:
[ 195.158998] CMDFIFO_STAT_0: 00002040
[ 195.159004] CMDFIFO_RDATA_0: c1000010
[ 195.159011] CMDP_OFFSET_0: 00000000
[ 195.159017] CMDP_CLASS_0: 00000000
[ 195.159024] CHANNELSTAT_0: 00000000
[ 195.159029] The CDMA sync queue is empty.
[ 195.159041]
[ 195.159046] NvHost basic channel registers:
[ 195.159052] CMDFIFO_STAT_0: 00002040
[ 195.159058] CMDFIFO_RDATA_0: 01282400
[ 195.159066] CMDP_OFFSET_0: 00000000
[ 195.159071] CMDP_CLASS_0: 00000000
[ 195.159077] CHANNELSTAT_0: 00000000
[ 195.159083] The CDMA sync queue is empty.
[ 195.159097]
[ 195.159104] sync_intc0mask = 0x00000001
[ 195.159111] sync_intmask = 0x50000003
[ 195.159115]
[ 195.159120]
[ 195.159128] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 195.159134] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 195.159141] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 195.159147] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 195.159153] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 195.159159] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 195.159165] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 195.159172] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 195.159183] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 195.159189] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 195.159195] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 195.159202] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 195.159208] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 195.159215] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 195.159221] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 195.159227] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 195.159233] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 195.159240] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 195.159246] syncpt_thresh_cpu0_int_status(18) = 0x00000000
[ 195.159252] syncpt_thresh_cpu0_int_status(19) = 0x00000000
[ 195.159258] syncpt_thresh_cpu0_int_status(20) = 0x00000000
[ 195.159264] syncpt_thresh_cpu0_int_status(21) = 0x00000000
[ 196.661704] fence timeout on [ffffffc1ea3b0600] after 1500ms
[ 196.661715] fence timeout on [ffffffc1ea3b09c0] after 1500ms
[ 196.661722] tegra194-vi5 15c10000.vi: vi_capture_status : no reply from camera processor
[ 196.661728] name=[nvhost_sync:31], current value=0 waiting value=27
[ 196.661745] ---- mlocks ----
[ 196.661758] tegra194-vi5 15c10000.vi: vi capture get status failed
[ 196.661796] ---- syncpts ----
[ 196.661907] id 22 (gv11b_510_user) min 27 max 0 refs 1 (previous client : )
[ 196.661928] id 34 (gv11b_506) min 3 max 3 refs 1 (previous client : )
[ 196.661933] id 35 (gv11b_505) min 4 max 4 refs 1 (previous client : )
[ 196.661938] id 36 (gv11b_504) min 3 max 3 refs 1 (previous client : )
[ 196.661942] id 37 (gv11b_503) min 3 max 3 refs 1 (previous client : )
[ 196.661954] id 38 (gv11b_502) min 3 max 3 refs 1 (previous client : )
[ 196.662076] name=[nvhost_sync:31], current value=0 waiting value=22
[ 196.662086] ---- mlocks ----
[ 196.662136] ---- syncpts ----
[ 196.662874] ---- channels ----
[ 196.662913]
[ 196.662916] id 22 (gv11b_510_user) min 27 max 0 refs 1 (previous client : )
[ 196.662923] NvHost basic channel registers:
[ 196.662934] CMDFIFO_STAT_0: 00002040
[ 196.662938] id 34 (gv11b_506) min 3 max 3 refs 1 (previous client : )
[ 196.662941] CMDFIFO_RDATA_0: 06041055
[ 196.662950] CMDP_OFFSET_0: 00000000
[ 196.662952] id 35 (gv11b_505) min 4 max 4 refs 1 (previous client : )
[ 196.662960] id 36 (gv11b_504) min 3 max 3 refs 1 (previous client : )
[ 196.662962] CMDP_CLASS_0: 00000000
[ 196.662967] CHANNELSTAT_0: 00000000
[ 196.662971] id 37 (gv11b_503) min 3 max 3 refs 1 (previous client : )
[ 196.662976] The CDMA sync queue is empty.
[ 196.662981] id 38 (gv11b_502) min 3 max 3 refs 1 (previous client : )
[ 196.662989]
[ 196.662995] NvHost basic channel registers:
[ 196.663002] CMDFIFO_STAT_0: 00002040
[ 196.663009] CMDFIFO_RDATA_0: c1000010
[ 196.663018] CMDP_OFFSET_0: 00000000
[ 196.663024] CMDP_CLASS_0: 00000000
[ 196.663030] CHANNELSTAT_0: 00000000
[ 196.663035] The CDMA sync queue is empty.
[ 196.663047]
[ 196.663052] NvHost basic channel registers:
[ 196.663058] CMDFIFO_STAT_0: 00002040
[ 196.663064] CMDFIFO_RDATA_0: 01282400
[ 196.663072] CMDP_OFFSET_0: 00000000
[ 196.663078] CMDP_CLASS_0: 00000000
[ 196.663084] CHANNELSTAT_0: 00000000
[ 196.663089] The CDMA sync queue is empty.
[ 196.663103]
[ 196.663110] sync_intc0mask = 0x00000001
[ 196.663116] sync_intmask = 0x50000003
[ 196.663121]
[ 196.663126]
[ 196.663134] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 196.663141] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 196.663147] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 196.663154] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 196.663161] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 196.663168] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 196.663175] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 196.663182] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 196.663188] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 196.663195] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 196.663201] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 196.663207] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 196.663214] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 196.663220] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 196.663226] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 196.663232] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 196.663239] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 196.663245] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 196.663251] syncpt_thresh_cpu0_int_status(18) = 0x00000000
[ 196.663257] syncpt_thresh_cpu0_int_status(19) = 0x00000000
[ 196.663263] syncpt_thresh_cpu0_int_status(20) = 0x00000000
[ 196.663270] syncpt_thresh_cpu0_int_status(21) = 0x00000000
[ 196.663856] ---- channels ----
[ 196.663888]
[ 196.663894] NvHost basic channel registers:
[ 196.663901] CMDFIFO_STAT_0: 00002040
[ 196.663907] CMDFIFO_RDATA_0: 06041055
[ 196.663917] CMDP_OFFSET_0: 00000000
[ 196.663923] CMDP_CLASS_0: 00000000
[ 196.663930] CHANNELSTAT_0: 00000000
[ 196.663936] The CDMA sync queue is empty.
[ 196.663947]
[ 196.663952] NvHost basic channel registers:
[ 196.663958] CMDFIFO_STAT_0: 00002040
[ 196.663965] CMDFIFO_RDATA_0: c1000010
[ 196.663972] CMDP_OFFSET_0: 00000000
[ 196.663978] CMDP_CLASS_0: 00000000
[ 196.663984] CHANNELSTAT_0: 00000000
[ 196.663990] The CDMA sync queue is empty.
[ 196.664001]
[ 196.664006] NvHost basic channel registers:
[ 196.664012] CMDFIFO_STAT_0: 00002040
[ 196.664018] CMDFIFO_RDATA_0: 01282400
[ 196.664025] CMDP_OFFSET_0: 00000000
[ 196.664031] CMDP_CLASS_0: 00000000
[ 196.664037] CHANNELSTAT_0: 00000000
[ 196.664042] The CDMA sync queue is empty.
[ 196.664057]
[ 196.664064] sync_intc0mask = 0x00000001
[ 196.664070] sync_intmask = 0x50000003
[ 196.664075]
[ 196.664080]
[ 196.664087] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 196.664093] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 196.664100] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 196.664107] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 196.664113] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 196.664119] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 196.664126] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 196.664132] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 196.664138] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 196.664145] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 196.664151] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 196.664157] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 196.664164] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 196.664170] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 196.664176] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 196.664182] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 196.664188] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 196.664195] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 196.664201] syncpt_thresh_cpu0_int_status(18) = 0x00000000
[ 196.664207] syncpt_thresh_cpu0_int_status(19) = 0x00000000
[ 196.664213] syncpt_thresh_cpu0_int_status(20) = 0x00000000
[ 196.664219] syncpt_thresh_cpu0_int_status(21) = 0x00000000
