Bayer histogram, userautoexposure and userautowhitebalance issues
I am working on color and exposure matching 2 cameras for 3D display.
I have found that the userautoexposure and userautowhite balance example programs do not work as expected.
I have identified at least 2 issues.
  1. Bayer histogram is improperly scaled.
  2. frame time and gain read from metadata are invalid.
  3. reports 3 devices when 2 are plugged in.
Here I will address issue 1 only. I will address issue 2 in a future post.
environment:
TX2 developer kit with leopard imaging 3 camera adapter board with 2 IMX477 cameras.
cat /proc/version
Linux version 4.9.140-tegra (simon@ubuntu) (gcc version 6.4.1 20170707 (Linaro GCC 6.4-2017.08) ) #1 SMP PREEMPT Tue Jul 23 21:55:19 CST 2019
Argus Version: 0.97.3 (multi-process)
To illustrate this issue I have added an option to the argus_histogram example to
use the bayer histogram metadata.
the output is below.
Code below.
  • Copyright © 2016 - 2018, NVIDIA CORPORATION. All rights reserved.
  • Redistribution and use in source and binary forms, with or without
  • modification, are permitted provided that the following conditions
  • are met:
    • Redistributions of source code must retain the above copyright
  • notice, this list of conditions and the following disclaimer.
    • Redistributions in binary form must reproduce the above copyright
  • notice, this list of conditions and the following disclaimer in the
  • documentation and/or other materials provided with the distribution.
    • Neither the name of NVIDIA CORPORATION nor the names of its
  • contributors may be used to endorse or promote products derived
  • from this software without specific prior written permission.
  • THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS’’ AND ANY
  • EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  • IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
  • PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
  • CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
  • EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
  • PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
  • PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
  • OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
  • (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  • OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include “ArgusHelpers.h”
#include “CommonOptions.h”
#include “Error.h”
#include “EGLGlobal.h”
#include “GLContext.h”
#include “Window.h”
#include “Thread.h”
#include <Argus/Argus.h>
#include <EGLStream/EGLStream.h>
#include <unistd.h>
#include <stdlib.h>
#include
#include
using namespace Argus;
namespace ArgusSamples
// Constants.
static const uint32_t DEFAULT_CAPTURE_TIME = 10; // In seconds.
static const uint32_t DEFAULT_CAMERA_INDEX = 0;
static const Rectangle<uint32_t> DEFAULT_WINDOW_RECT(0, 0, 1024, 768);
static const Size2D<uint32_t> STREAM_SIZE(640, 480);
// Due to clipping and differences in color correction algorithms, the
// upper-most bins may negatively affect the graph scaling. This constant
// specifies how many of the upper-most bins are excluded from the graphs.
static const uint32_t CLIP_BINS = 10;
// Globals.
UniqueObj g_cameraProvider;
EGLDisplayHolder g_display;
// Debug print macros.
#define PRODUCER_PRINT(…) printf("PRODUCER: " VA_ARGS)
#define CONSUMER_PRINT(…) printf("CONSUMER: " VA_ARGS)
  • Extended options class to add additional options specific to this sample.
    class HistogramSampleOptions : public CommonOptions
    public:
    HistogramSampleOptions(const char *programName)
    : CommonOptions(programName,
    ArgusSamples::CommonOptions::Option_D_CameraDevice |
    ArgusSamples::CommonOptions::Option_M_SensorMode |
    ArgusSamples::CommonOptions::Option_R_WindowRect |
    ArgusSamples::CommonOptions::Option_T_CaptureTime)
    , m_useBayer(0)
    addOption(createValueOption
    (“usebayer”, ‘b’, “0 or 1”, “Use Bayer histogram (instead of RGB).”, m_useBayer));
    int useBayer() const { return m_useBayer.get(); }
protected:
Value m_useBayer;
  • Histogram Consumer thread:
  • Opens an on-screen GL window, and renders a live camera preview with
  • histogram overlays.
    class ConsumerThread : public Thread
    public:
    explicit ConsumerThread(const HistogramSampleOptions& options, EGLStreamKHR stream)
    : m_options(options)
    , m_stream(stream)
    , m_streamTexture(0)
    , m_textureProgram(0)
    , m_histogramProgram(0)
    , m_histogramTexture(0)
    , m_colorMaskLoc(0)
    , m_binMaxLoc(0)
    , m_combinedLoc(0)
    uint32_t yDiv = HISTOGRAM_COUNT + 1;
    m_histogramSpacing = options.windowRect().height() / (yDiv * yDiv);
    m_histogramSize = Size2D<uint32_t>(
    options.windowRect().width() / 2 - (m_histogramSpacing * 2),
    options.windowRect().height() / yDiv);
~ConsumerThread()
enum HistogramType
    HISTOGRAM_R,
    HISTOGRAM_G,
    HISTOGRAM_B,
    HISTOGRAM_RGB,
    HISTOGRAM_COMBINED,
    HISTOGRAM_COUNT
private:
/** @name Thread methods /
virtual bool threadInitialize();
virtual bool threadExecute();
virtual bool threadShutdown();
 * Renders a single histogram to the display.
 * @param[in] type The HistogramType being rendered.
 * @param[in] label The label/title for the histogram.
 * @param[in] max The maximum value containined in the histogram.
 * @param[in] colorMask The color mask to use for the shader.
void renderHistogram(HistogramType type, const char* label,
                     uint32_t max, RGBTuple<float> colorMask);
const HistogramSampleOptions& m_options;
EGLStreamKHR m_stream;
GLContext m_context;
GLuint m_streamTexture;
GLuint m_textureProgram;
GLuint m_histogramProgram;
GLuint m_histogramTexture;
GLuint m_colorMaskLoc;
GLuint m_binMaxLoc;
GLuint m_combinedLoc;
Size2D<uint32_t> m_histogramSize;
uint32_t m_histogramSpacing;
bool ConsumerThread::threadInitialize()
Window &window = Window::getInstance();
// Create the context and make it current.
CONSUMER_PRINT("Creating context.\n");
PROPAGATE_ERROR(m_context.initialize(&window));
PROPAGATE_ERROR(m_context.makeCurrent());
// Create the shader program to render the texture.
    static const char vtxSrc[] =
        "#version 300 es\n"
        "in layout(location = 0) vec2 coord;\n"
        "out vec2 texCoord;\n"
        "void main() {\n"
        "  gl_Position = vec4((coord * 2.0) - 1.0, 0.0, 1.0);\n"
        "  texCoord = vec2(coord.x, 1.0 - coord.y);\n"
        "}\n";
    static const char frgSrc[] =
        "#version 300 es\n"
        "#extension GL_OES_EGL_image_external : require\n"
        "precision highp float;\n"
        "uniform samplerExternalOES texSampler;\n"
        "in vec2 texCoord;\n"
        "out vec4 fragColor;\n"
        "void main() {\n"
        "  fragColor = texture2D(texSampler, texCoord);\n"
        "}\n";
    PROPAGATE_ERROR(m_context.createProgram(vtxSrc, frgSrc, &m_textureProgram));
    glUseProgram(m_textureProgram);
    glUniform1i(glGetUniformLocation(m_textureProgram, "texSampler"), 0);
// Create the shader program to render the histograms.
        "#version 300 es\n"
        "out vec2 binCoord;\n"
        "void main() {\n"
        "  binCoord = coord;\n"
        "}\n";
        "#version 300 es\n"
        "uniform usampler2D histogramSampler;\n"
        "uniform float binMax;\n"
        "uniform vec4 colorMask;\n"
        "uniform bool combined;\n"
        "in vec2 binCoord;\n"
        "void main() {\n"
        "  if (combined) {\n"
        "    uint totalCount = texture2D(histogramSampler, binCoord).a;\n"
        "    float totalValue = float(totalCount) / binMax;\n"
        "    fragColor = vec4(vec3(step(binCoord.y, totalValue)), colorMask.a);\n"
        "  } else {\n"
        "    uvec3 rgbCounts = texture2D(histogramSampler, binCoord).rgb;\n"
        "    vec3 binValues = vec3(rgbCounts) / binMax;\n"
        "    fragColor = colorMask * vec4(step(binCoord.y, binValues), 1.0);\n"
        "  }\n"
        "}\n";
    PROPAGATE_ERROR(m_context.createProgram(vtxSrc, frgSrc, &m_histogramProgram));
    glUniform1i(glGetUniformLocation(m_histogramProgram, "histogramSampler"), 0);
    m_binMaxLoc = glGetUniformLocation(m_histogramProgram, "binMax");
    m_colorMaskLoc = glGetUniformLocation(m_histogramProgram, "colorMask");
    m_combinedLoc = glGetUniformLocation(m_histogramProgram, "combined");
// Initialize the vertex attrib state (used for both shader programs).
static const GLfloat quadCoords[] = {1.0f, 0.0f, 1.0f, 1.0f, 0.0f, 0.0f, 0.0f, 1.0f};
glVertexAttribPointer(0, 2, GL_FLOAT, GL_FALSE, 0, quadCoords);
glEnableVertexAttribArray(0);
// Enable alpha blending.
glEnable(GL_BLEND);
glBlendFunc(GL_SRC_ALPHA, GL_ONE_MINUS_SRC_ALPHA);
// Set text parameters.
m_context.setTextSize(16.0f / m_histogramSize.height(),
                      (float)m_histogramSize.height() / (float)m_histogramSize.width());
m_context.setTextColor(1.0f, 1.0f, 1.0f);
m_context.setTextBackground(0.0f, 0.0f, 0.0f, 0.5f);
// Create a 1D integer texture to store the histogram values.
glGenTextures(1, &m_histogramTexture);
glBindTexture(GL_TEXTURE_2D, m_histogramTexture);
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA32UI, 1, 1, 0, GL_RGBA_INTEGER, GL_UNSIGNED_INT, NULL);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP_TO_EDGE);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP_TO_EDGE);
// Create an external texture and connect it to the stream as the consumer.
CONSUMER_PRINT("Connecting to stream.\n");
glGenTextures(1, &m_streamTexture);
glBindTexture(GL_TEXTURE_EXTERNAL_OES, m_streamTexture);
if (!eglStreamConsumerGLTextureExternalKHR(g_display.get(), m_stream))
    ORIGINATE_ERROR("Unable to connect GL as consumer");
CONSUMER_PRINT("Connected to stream.\n");
// Set the acquire timeout to infinite.
eglStreamAttribKHR(g_display.get(), m_stream, EGL_CONSUMER_ACQUIRE_TIMEOUT_USEC_KHR, -1);
return true;
bool ConsumerThread::threadExecute()
// Wait until the Argus producer is connected.
CONSUMER_PRINT(“Waiting until producer is connected…\n”);
while (true)
EGLint state = EGL_STREAM_STATE_CONNECTING_KHR;
if (!eglQueryStreamKHR(g_display.get(), m_stream, EGL_STREAM_STATE_KHR, &state))
ORIGINATE_ERROR(“Failed to query stream state (possible producer failure).”);
if (state != EGL_STREAM_STATE_CONNECTING_KHR)
break;
usleep(1000);
CONSUMER_PRINT(“Producer is connected; continuing.\n”);
// Render until there are no more frames (the producer has disconnected).
uint32_t frame = 0;
while (eglStreamConsumerAcquireKHR(g_display.get(), m_stream))
    frame++;
    CONSUMER_PRINT("Acquired frame %d. Rendering.\n", frame);
    // Render the image.
    glViewport(0, 0, m_options.windowRect().width(), m_options.windowRect().height());
    glDrawArrays(GL_TRIANGLE_STRIP, 0, 4);
    // Get the metadata from the current EGLStream frame.
    // Note: This will likely fail for the last frame since the producer has
    //       already disconected from the EGLStream, so we need to handle
    //       failure gracefully.
    UniqueObj<EGLStream::MetadataContainer> metadataContainer(
        EGLStream::MetadataContainer::create(g_display.get(), m_stream));
    EGLStream::IArgusCaptureMetadata *iArgusCaptureMetadata =
        interface_cast<EGLStream::IArgusCaptureMetadata>(metadataContainer);
    if (iArgusCaptureMetadata)
        CaptureMetadata *metadata = iArgusCaptureMetadata->getMetadata();
        const ICaptureMetadata* iMetadata = interface_cast<const ICaptureMetadata>(metadata);
        if (!iMetadata)
            ORIGINATE_ERROR("Failed to get Argus metadata\n");
        std::vector< Tuple<4, uint32_t> > rgbaData;
        if (m_options.useBayer() == 1)
            // Read the Bayer histogram.
            std::cout << "Bayer Histogram" << std::endl;
            std::vector< BayerTuple<uint32_t> > histogram;
            const IBayerHistogram* bayerHistogram =
                interface_cast<const IBayerHistogram>(iMetadata->getBayerHistogram());
            if (!bayerHistogram || bayerHistogram->getHistogram(&histogram) != STATUS_OK)
                ORIGINATE_ERROR("Failed to get histogram data\n");
            // Generate RGBA data by combining gEven/Odd channels and putting
            // combined totals into alpha channel.
            rgbaData.resize(histogram.size() - CLIP_BINS);
            for (uint32_t i = 0; i < histogram.size() - CLIP_BINS; i++)
                rgbaData[i][0] = histogram[i].r();
                rgbaData[i][1] = (histogram[i].gEven() + histogram[i].gOdd()) / 2;
                rgbaData[i][2] = histogram[i].b();
                rgbaData[i][3] = rgbaData[i][0] + rgbaData[i][1] + rgbaData[i][2];
        else
            // Read the RGB histogram.
            std::cout << "RGB Histogram" << std::endl;
            std::vector< RGBTuple<uint32_t> > histogram;
            const IRGBHistogram* rgbHistogram =
                interface_cast<const IRGBHistogram>(iMetadata->getRGBHistogram());
            if (!rgbHistogram || rgbHistogram->getHistogram(&histogram) != STATUS_OK)
            // Generate RGBA data by appending totals into alpha channel.
                rgbaData[i][1] = histogram[i].g();
        // Push histogram data into the texture.
        glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA32UI, rgbaData.size(), 1, 0,
                     GL_RGBA_INTEGER, GL_UNSIGNED_INT, &rgbaData[0]);
        // Determine the maximum values, used for graph scaling.
        Tuple<4, uint32_t> maxValues(0);
        for (uint32_t i = 0; i < rgbaData.size(); i++)
            maxValues[0] = std::max(rgbaData[i][0], maxValues[0]);
            maxValues[1] = std::max(rgbaData[i][1], maxValues[1]);
            maxValues[2] = std::max(rgbaData[i][2], maxValues[2]);
            maxValues[3] = std::max(rgbaData[i][3], maxValues[3]);
        uint rgbMax = std::max(maxValues[0], std::max(maxValues[1], maxValues[2]));
        // Render histograms.
        renderHistogram(HISTOGRAM_R, "Red", maxValues[0], RGBTuple<float>(1.0f, 0.0f, 0.0f));
        renderHistogram(HISTOGRAM_G, "Green", maxValues[1], RGBTuple<float>(0.0f, 1.0f, 0.0f));
        renderHistogram(HISTOGRAM_B, "Blue", maxValues[2], RGBTuple<float>(0.0f, 0.0f, 1.0f));
        renderHistogram(HISTOGRAM_RGB, "RGB", rgbMax, RGBTuple<float>(1.0f, 1.0f, 1.0f));
        renderHistogram(HISTOGRAM_COMBINED, "Overall", maxValues[3],
    PROPAGATE_ERROR(m_context.swapBuffers());
CONSUMER_PRINT("No more frames. Cleaning up.\n");
PROPAGATE_ERROR(requestShutdown());
return true;
void ConsumerThread::renderHistogram(HistogramType type, const char* label,
uint32_t max, RGBTuple colorMask)
const Rectangle<uint32_t> &window = m_options.windowRect();
const Point2D<uint32_t> origin(
window.width() / 2 + m_histogramSpacing,
window.height() - (m_histogramSpacing + m_histogramSize.height()) * (type + 1));
// Render histogram
glUseProgram(m_histogramProgram);
glUniform1i(m_combinedLoc, type == HISTOGRAM_COMBINED);
glUniform1f(m_binMaxLoc, max);
glUniform4f(m_colorMaskLoc, colorMask.r(), colorMask.g(), colorMask.b(), 0.8f);
glViewport(origin.x(), origin.y(), m_histogramSize.width(), m_histogramSize.height());
// Render text.
std::ostringstream stream;
    stream << "(Bayer) Max:" << std::setw(7) << max;
else
    stream << "(RGB) Max:" << std::setw(7) << max;
m_context.setTextPosition(0.02f, 0.98f);
m_context.renderText(label);
m_context.setTextPosition(0.60f, 0.96f);
m_context.renderText(stream.str().c_str());
bool ConsumerThread::threadShutdown()
glDeleteProgram(m_textureProgram);
glDeleteProgram(m_histogramProgram);
glDeleteTextures(1, &m_streamTexture);
glDeleteTextures(1, &m_histogramTexture);
m_context.cleanup();
CONSUMER_PRINT("Done.\n");
return true;
  • Argus Producer thread:
  • Opens the Argus camera driver, creates an OutputStream to be consumed by
  • the GL consumer, then performs repeating capture requests for CAPTURE_TIME
  • seconds before closing the producer and Argus driver.
    static bool execute(const HistogramSampleOptions& options)
    // Initialize the window and EGL display.
    window.setWindowRect(options.windowRect());
    PROPAGATE_ERROR(g_display.initialize(window.getEGLNativeDisplay()));
// Initialize the Argus camera provider.
g_cameraProvider = UniqueObj<CameraProvider>(CameraProvider::create());
ICameraProvider *iCameraProvider = interface_cast<ICameraProvider>(g_cameraProvider);
if (!iCameraProvider)
    ORIGINATE_ERROR("Failed to get ICameraProvider interface");
printf("Argus Version: %s\n", iCameraProvider->getVersion().c_str());
// Get the selected camera device and sensor mode.
CameraDevice* cameraDevice = ArgusHelpers::getCameraDevice(
        g_cameraProvider.get(), options.cameraDeviceIndex());
if (!cameraDevice)
    ORIGINATE_ERROR("Selected camera device is not available");
SensorMode* sensorMode = ArgusHelpers::getSensorMode(cameraDevice, options.sensorModeIndex());
ISensorMode *iSensorMode = interface_cast<ISensorMode>(sensorMode);
if (!iSensorMode)
    ORIGINATE_ERROR("Selected sensor mode not available");
// Create the capture session using the specified device and get its interfaces.
UniqueObj<CaptureSession> captureSession(iCameraProvider->createCaptureSession(cameraDevice));
ICaptureSession *iCaptureSession = interface_cast<ICaptureSession>(captureSession);
IEventProvider *iEventProvider = interface_cast<IEventProvider>(captureSession);
if (!iCaptureSession || !iEventProvider)
    ORIGINATE_ERROR("Failed to create CaptureSession");
// Create the OutputStream.
PRODUCER_PRINT("Creating output stream\n");
UniqueObj<OutputStreamSettings> streamSettings(
    iCaptureSession->createOutputStreamSettings(STREAM_TYPE_EGL));
IEGLOutputStreamSettings *iEGLStreamSettings =
    interface_cast<IEGLOutputStreamSettings>(streamSettings);
if (iEGLStreamSettings)
    iEGLStreamSettings->setPixelFormat(PIXEL_FMT_YCbCr_420_888);
    iEGLStreamSettings->setResolution(Size2D<uint32_t>(options.windowRect().width(),
                                                       options.windowRect().height()));
    iEGLStreamSettings->setEGLDisplay(g_display.get());
    iEGLStreamSettings->setMetadataEnable(true);
UniqueObj<OutputStream> outputStream(iCaptureSession->createOutputStream(streamSettings.get()));
IEGLOutputStream *iEGLOutputStream = interface_cast<IEGLOutputStream>(outputStream);
if (!iEGLOutputStream)
    ORIGINATE_ERROR("Failed to create EGLOutputStream");
// Launch the consumer thread to consume frames from the OutputStream's EGLStream.
PRODUCER_PRINT("Launching consumer thread\n");
ConsumerThread consumerThread(options, iEGLOutputStream->getEGLStream());
PROPAGATE_ERROR(consumerThread.initialize());
// Wait until the consumer is connected to the stream.
PROPAGATE_ERROR(consumerThread.waitRunning());
// Create capture request and enable output stream.
UniqueObj<Request> request(iCaptureSession->createRequest());
IRequest *iRequest = interface_cast<IRequest>(request);
if (!iRequest)
    ORIGINATE_ERROR("Failed to create Request");
iRequest->enableOutputStream(outputStream.get());
// Set the sensor mode in the request.
ISourceSettings *iSourceSettings = interface_cast<ISourceSettings>(request);
if (!iSourceSettings)
    ORIGINATE_ERROR("Failed to get source settings request interface");
iSourceSettings->setSensorMode(sensorMode);
// Submit capture requests.
PRODUCER_PRINT("Starting repeat capture requests.\n");
if (iCaptureSession->repeat(request.get()) != STATUS_OK)
    ORIGINATE_ERROR("Failed to start repeat capture request");
// Wait for specified number of seconds.
PROPAGATE_ERROR(window.pollingSleep(options.captureTime()));
// Stop the repeating request and wait for idle.
iCaptureSession->stopRepeat();
iCaptureSession->waitForIdle();
// Destroy the output stream. This destroys the EGLStream which causes
// the GL consumer acquire to fail and the consumer thread to end.
outputStream.reset();
// Wait for the consumer thread to complete.
PROPAGATE_ERROR(consumerThread.shutdown());
// Shut down Argus.
g_cameraProvider.reset();
// Shut down the window (destroys window's EGLSurface).
window.shutdown();
// Cleanup the EGL display
PROPAGATE_ERROR(g_display.cleanup());
PRODUCER_PRINT("Done -- exiting.\n");
return true;
}; // namespace ArgusSamples
int main(int argc, char** argv)
ArgusSamples::HistogramSampleOptions options(basename(argv[0]));
if (!options.parse(argc, argv))
return EXIT_FAILURE;
if (options.requestedExit())
return EXIT_SUCCESS;
if (!ArgusSamples::execute(options))
What do you mean improperly scaled?
What’s the resolution of the imx477?
Shane,
I would expect that the 2 histograms look similar.
by properly scaled, I mean that the data is all in the first few bins of the histogram instead of being in the midranges of the histogram as the rgb histogram has it. note that the 2 images look the same.
the peak of the RGB histogram is at 253/470 or .533 or 138 if it was an 8 bit image.
the peak of the Bayer histogram is at 5/470 or .106 or 3 if it was an 8 bit image.
it looks like the data is shifted down by 6 bits.
this looks that the 10 bit data is being put in the high bits of a 16 bit short instead of the low bits of the 16 bit short at some point.
4056H x3040V 10 bits per pixel
-mike
What’s the different for those two image?
the 2 images posted are screen captures of the output of the histogram example application.
they were taken one after another without moving the camera. one shows the RGB histogram and the other shows the bayer histogram.
the code adds an option to the example code to switch between bayer and rgb histograms.
argus_histogram -b 1 gets the bayer histogram.
Could you attached the source code and binary by rename the sub file name.
this is the main file from examples/argus/samples/histogram with modifications.
-mike
main.cpp (22.6 KB)
argus_histogram (895.6 KB)
the binary.
Could you try to set the ISP digital gain range to 1 -1
You can reference to argus_camera to set it by setIspDigitalGainRange()
Shane,
added
// get auto control settings interface
Argus::IAutoControlSettings *iAutoControlSettings =
Argus::interface_castArgus::IAutoControlSettings(iRequest->getAutoControlSettings());
if (!iAutoControlSettings)
ORIGINATE_ERROR(“Failed to get IAutoControlSettings interface”);
iAutoControlSettings->setIspDigitalGainRange(Range(1.0,-1.0));
at line 514.
no change in the Bayer histogram.
why did you expect this to make a difference?
has your team duplicated my results?
-mike
looks like the types got stripped from the templates…
I just try to run the APP it’s looks like there’s no much different.
I saw this APP have capture few frames with different exposure/gain, I think you need to check the sensor exposure and gain are the same to compare it.
what camera were you using?
did the output look like the 2 images that I downloaded at the start of this thread?
notice that the images behind the histograms look like they are of the same brightness.
notice that the bayer histogram
does not reflect the brightness of the image behind it.
the sensor exposure and gain are the same.
should we take this offline you can call me this will improve the bandwidth.
Shane,
To see the issue run you must give specify the algorithm for the argus_histogram application.
argus_histogram -t 60 -b 0
will run the standard case for 60 seconds. This uses the RGB histogram and is normal.
argus_histogram -t 60 -b1
will run the degenerate case for 60 seconds.
Note the image behind the histogram looks well exposed. The histogram indicates that the image is nearly black.
please let me know if it looks like the images I provided for you.
I expect that the bug is dealing with the 10 bit per pixel camera. If your camera is not 10 bpp you may not see the bug.
-mike
shane,
do you have any solutions?
Hi
I have issue you question internal to check if can get solution.
thank you.
