Bayer raw 12-bit encoding with NVENC
What possibilities do we have to encode 12, 14, or 16-bit Raw Bayer images using NVENC H.264/H.265/VP9 encoding? I see the 10-bit input source case in the img_enc sample applications, but not >12. Also, Can we use lossless encoding?
Dear touraj,
Could you please let me know what is your use case for this topic in detail?
The use-case is image sensor raw Bayer lossless compression using NVENC with bits per pixel greater or equal 12.
Dear touraj,
Xavier supports up to 10 bits encoding next gen SoC will cover 12 bit encoding.
Is the lossless encoding for image dataset training? Thanks.
