Hello guys.
I just started experimenting with Isaac SDK and I’m trying to run the examples inside a docker image.
the SDK builds successfully but when I try to run
bazel build //apps//samples//stereo_dummy
it fails with the following log
ERROR: infinite symlink expansion detected
[start of symlink chain]
/home/username/.cache/bazel/_bazel_username/799ab820b3e0be9b8066253adb007746/external/com_nvidia_isaac
/home/username
[end of symlink chain]
ERROR: /home/username/.cache/bazel/_bazel_username/799ab820b3e0be9b8066253adb007746/external/toolchain/crosstool/BUILD:62:1: no such package '@com_nvidia_isaac//engine/build': Could not access /home/username/.cache/bazel/_bazel_username/799ab820b3e0be9b8066253adb007746/external/com_nvidia_isaac: Infinite symlink expansion and referenced by '@toolchain//crosstool:gcc_or_nvcc'
ERROR: /home/username/third_party/BUILD:13:1: error loading package '@cuda_x86_64//': Encountered error while reading extension file 'third_party/cuda.bzl': no such package '@com_nvidia_isaac//third_party': Could not access /home/username/.cache/bazel/_bazel_username/799ab820b3e0be9b8066253adb007746/external/com_nvidia_isaac: Infinite symlink expansion and referenced by '//third_party:nppc'
ERROR: /home/username/third_party/BUILD:13:1: error loading package '@cuda_x86_64//': Encountered error while reading extension file 'third_party/cuda.bzl': no such package '@com_nvidia_isaac//third_party': Could not access /home/username/.cache/bazel/_bazel_username/799ab820b3e0be9b8066253adb007746/external/com_nvidia_isaac: Infinite symlink expansion and referenced by '//third_party:nppitc'
ERROR: /home/username/third_party/BUILD:13:1: error loading package '@cuda_x86_64//': Encountered error while reading extension file 'third_party/cuda.bzl': no such package '@com_nvidia_isaac//third_party': Could not access /home/username/.cache/bazel/_bazel_username/799ab820b3e0be9b8066253adb007746/external/com_nvidia_isaac: Infinite symlink expansion and referenced by '//third_party:npps'
ERROR: /home/username/third_party/BUILD:13:1: error loading package '@cuda_x86_64//': Encountered error while reading extension file 'third_party/cuda.bzl': no such package '@com_nvidia_isaac//third_party': Could not access /home/username/.cache/bazel/_bazel_username/799ab820b3e0be9b8066253adb007746/external/com_nvidia_isaac: Infinite symlink expansion and referenced by '//third_party:nppial'
ERROR: /home/username/third_party/BUILD:13:1: error loading package '@cuda_x86_64//': Encountered error while reading extension file 'third_party/cuda.bzl': no such package '@com_nvidia_isaac//third_party': Could not access /home/username/.cache/bazel/_bazel_username/799ab820b3e0be9b8066253adb007746/external/com_nvidia_isaac: Infinite symlink expansion and referenced by '//third_party:nppig'
ERROR: /home/username/third_party/BUILD:13:1: error loading package '@cuda_x86_64//': Encountered error while reading extension file 'third_party/cuda.bzl': no such package '@com_nvidia_isaac//third_party': Could not access /home/username/.cache/bazel/_bazel_username/799ab820b3e0be9b8066253adb007746/external/com_nvidia_isaac: Infinite symlink expansion and referenced by '//third_party:nppif'
ERROR: /home/username/third_party/BUILD:13:1: error loading package '@cuda_x86_64//': Encountered error while reading extension file 'third_party/cuda.bzl': no such package '@com_nvidia_isaac//third_party': Could not access /home/username/.cache/bazel/_bazel_username/799ab820b3e0be9b8066253adb007746/external/com_nvidia_isaac: Infinite symlink expansion and referenced by '//third_party:cudart'
ERROR: /home/username/third_party/BUILD:13:1: error loading package '@cuda_x86_64//': Encountered error while reading extension file 'third_party/cuda.bzl': no such package '@com_nvidia_isaac//third_party': Could not access /home/username/.cache/bazel/_bazel_username/799ab820b3e0be9b8066253adb007746/external/com_nvidia_isaac: Infinite symlink expansion and referenced by '//third_party:nppidei'
ERROR: /home/username/engine/gems/image/BUILD:43:1: no such package '@com_nvidia_isaac//third_party': Could not access /home/username/.cache/bazel/_bazel_username/799ab820b3e0be9b8066253adb007746/external/com_nvidia_isaac: Infinite symlink expansion and referenced by '//engine/gems/image:cuda_conversions'
ERROR: /home/username/engine/gems/image/BUILD:14:1: error loading package '@libjpeg//': Encountered error while reading extension file 'engine/build/template.bzl': no such package '@com_nvidia_isaac//engine/build': Could not access /home/username/.cache/bazel/_bazel_username/799ab820b3e0be9b8066253adb007746/external/com_nvidia_isaac: Infinite symlink expansion and referenced by '//engine/gems/image:image'
ERROR: /home/username/third_party/BUILD:13:1: error loading package '@cuda_x86_64//': Encountered error while reading extension file 'third_party/cuda.bzl': no such package '@com_nvidia_isaac//third_party': Could not access /home/username/.cache/bazel/_bazel_username/799ab820b3e0be9b8066253adb007746/external/com_nvidia_isaac: Infinite symlink expansion and referenced by '//third_party:cuda'
WARNING: errors encountered while analyzing target '//apps/samples/stereo_dummy:stereo_dummy': it will not be built
INFO: Analysed target //apps/samples/stereo_dummy:stereo_dummy (0 packages loaded, 0 targets configured).
INFO: Found 0 targets...
ERROR: command succeeded, but there were loading phase errors
INFO: Elapsed time: 2.402s, Critical Path: 0.00s, Remote (0.00% of the time): [queue: 0.00%, setup: 0.00%, process: 0.00%]
INFO: 0 processes.
FAILED: Build did NOT complete successfully
I’m using Nvidia Cudagl as a base image for my docker.
what im doing wrong?
