Hi, I apologize for how trivial some of my questions will be, I foresee myself asking alot of them here but hopefully I’ll be able to find some help! I’ve programmed in CUDA before, and understand it pretty well. I don’t have much experience with FORTRAN although I’m not completely useless with it. Anyways, I’m trying to convert a routine that’s already written in FORTRAN to run in cudafortran.
I have made my first runthrough at coding it and can’t seem to get it to debug. When I try to compile/run it I get these errors:
PGF90-S-0070-Incorrect sequence of statements (rieman.F90: 97)
PGF90-F-0004-Corrupt or Old Module file ./hydro_data.mod (rieman.F90: 118)
The lines listed here are the first lines of code in the file and they consist of simply:
use cudafor
subroutine rieman (numIntCells, numCells, &
rhoav, uav, utav, uttav, pav, &
urell, ugrdl, game, gameav, xnav, x)
Since this routine is part of a much larger module, I have to make the whole thing with the command gmake --jobs=8
in the makefile.h i’ve tried changing the compiler and linker to use pgf90 as opposed to mpif90 but this didnt work. Any idea what I’m doing wrong here?
