I am a SWE student, and I am working on a project right now to create a realistic pool of water using the Quake 3 engine as a base.
Now, all of the reading I have done points to using FFT to create a realistic wave pool simulation, and CUDA has the FFT built in, however I am having trouble making use of the CUDA libraries (in particular the cufft) in a standard C/C++ file.
If you have a copy of Matlab laying around you can use AccelerEyes’ Jacket to do some of the prototyping for this from the surface geometry to the shaders. It seems as though the various ways of simulating a water surface port well to the GPU and we have put together a few ourselves:
The ocean examples are probably the most relevant since they use FFT. This way you don’t have to spend time in C/C++ initially and might get to an end product faster.
