I’ve been loading a script to show a dashboard in VR via the python scriping attribute on an Xform, and for some reason it doesnt work anymore.
There is no error, just this warning:
TIME [Warning] [omni.kit.widget.filebrowser.grid_view] Failed to select and center item [ PATH to my main USD file ] in file browser grid view.
it doesnt work in both kit 105 and 106. While the script initially didnt work in 106 due to some changes to one of the utilizes extensions, after fixing all the errors, i now get the same error in kit 106 as well (composer build from the template with a few extra extensions.)
Every once in a while i also get:
TIME [Warning] [omni.ui] omni::ui::GpuResourcesCache: trying to release non-existent cached GPU resource ‘c:/users/MYUSERNAME/appdata/local/ov/pkg/create-2023.2.5/extscache/omni.kit.window.filepicker-2.10.14+ece658d9/icons/ov_logo.png:2024-10-11@16:36:32’
Do you have any isnsight why this suddenly pops up ? is this simply due to omni.kit.scripting being in Beta, or something else ?
Best Regards,
Julius
