Jetson AGX XAVIER
L4T 32.7.2
I would like to see if the bash shell will start after a SW update fails due to a power outage or some other reason.
To confirm the above behavior, we tried the following, as described in the Deveroper Guide.
If rootfs A/B is disabled on the target it boots to the recovery kernel, which runs the OTA update process after executing this step. If the update fails due to power loss, the target device can reboot into the recovery kernel and continue the update. The maximum number of times the target device reboots and continues the update is determined by the script variable OTA_MAX_RETRY_COUNT, which defaults to 0 (zero). If the update fails more than that number of times the target device boots to the recovery kernel and enters the bash shell. You can change the value of OTA_MAX_RETRY_COUNT in ${TARGET_BSP}/tools/ota_tools/version_upgrade/nv_recovery.sh.
The conditions under which we tried are as follows:
- A/B Redundancy: Disabled
- RootfsAB: Disabled
- OTA_MAX_RETRY_COUNT = 0
The following internal verifications were performed under the above conditions.
- Perform Preparing for an Image-Based OTA Update on this site
- Steps Performed on the Jetson Device at 7. Power OFF>ON during reboot
- Confirm that rebooting beyond the value of OTA_MAX_RETRY_COUNT will launch the recovery kernel and enter the bash shell
As a result of the verification, the expected 3. behavior was not obtained.
At 2. I tried changing the timing of the restart while checking the logs, but it did not work.
An example of a log of the following implementation is shown below.
reboot_during_OTAupdate.txt (256.4 KB)
What could be the reason why the expected behavior was not obtained?
