Behavior with "negative" reference to character
I am not sure if what I’m describing below is a bug, or a different opinion of the Fortran standard, or what, but I thought I’d ask about it here. If nothing else, maybe I could request PGI change their error reporting.
Namely, a program recently failed with an odd error:
0: ALLOCATE: 18446744073709551615 bytes requested; not enough memory
It only ever failed on PGI; Intel passed it just fine. After some quite laborious stepping through a program with Totalview, the problem was found to be due to referencing a character string with a negative index. An example reproducer is below:
program test
implicit none
character(len=128) :: tmp, argl, argr, expr
integer :: pos
expr = '12345'
tmp = trim(expr)
!pos = 3
pos = 0
argl= adjustl(tmp(:pos-1))
argr= adjustl(tmp(pos+1:))
write (*,*) 'tmp:  ',tmp
write (*,*) 'argl: ',argl
write (*,*) 'argr: ',argr
end program test
If you run this with ‘pos=3’ above, it does what you expect:
> ./a.out
 tmp:
 12345
 argl:
 12
 argr:
 45
Now, try it with ‘pos = 0’ and:
> ./a.out
So, the issue is evaluating:
argl= adjustl(tmp(:-1))
Obviously, this isn’t something you want to do. The reason this code ever worked on Intel (V 11) is because Intel has a different behavior. If ‘pos=0’ then:
> ./a.out
 tmp:
 12345
 argl:
 argr:
 12345
It is this behavior the program was expecting. Likewise with gfortran (v 4.1.2):
> ./a.out
 tmp:  12345
 argl:
 argr: 12345
So, I guess I’m asking one of two things:
  • Which behavior is correct according to the standard? That is, should we expect a compiler to behave like Intel or like PGI?
  • If PGI is correct, is it possible to get a more descriptive error with this? Under Totalview (with -g), the program doesn’t actually trigger anything, but just exits out. It’s hard to debug when the debugger doesn’t see this as an issue.
Thanks,
Matt
Just a note that the same error:
is thrown if you do all of the above with an integer array instead, i.e.:
pos = 0
itmp = [1,2,3,4,5]
iargl = -99999
iargr = -99999
iargl(:pos-1) = itmp(:pos-1)
iargr(pos+1:) = itmp(pos+1:)
write (*,*) 'itmp:  ',itmp
write (*,*) 'iargl: ',iargl
write (*,*) 'iargr: ',iargr
gfortran throws:
 itmp:             1           2           3           4           5
 iargl:       -99999      -99999      -99999      -99999      -99999
 iargr:            1           2           3           4           5
I’m beginning to suspect the standard doesn’t say what to do in these situations, so it’s the vendor’s/implementer’s choice…
Hi Matt,
Thanks for narrowing this down. It does look like a compiler error in that it should be checking for the case where the ending position is less then the starting. The length should be set to 0 here but it looks like we’re passing a negative value when allocating the temp string.
I’ve submitted a problem report (TPR#18608) and sent it off to Engineering. We’ve missed the cut-off for 12.4 so I requested this be fixed by the 12.5 release.
Thanks again for the great example.
  • Mat
