I have been searching through the internet, but can’t find anything useful. I am looking for some application, that can be used to compare the performance between CPU (emu mode) and GPU.
I have never tried running them on anything other than linux… You could contact the authors of each project directly to see if they can help you with a windows build or you could try modifying the sources themselves (many of them are just a few .cu files that should be more or less platform independent ). I am not currently aware of any releases of CUDA benchmarks for windows.
I am a little curious as to why you want to compare the performance of a CUDA application running on a real GPU vs. running in emulation mode and what value this comparison would have.
First of all, I am just a user with no or minimum C/CUDA knowledge. Let’s go down to my level:)
Secondly, I was told that emu mode is performing well compared to CPU preferred app. I guess it’s not like this.
I am opened to suggestions, all I need to do is compare two, maybe three application that do the same thing, but once on CPU (Q, I7…) and once on a multiGPU (295GTX).
if all you really are looking for are some applications that you can run in CPU and GPU mode, HOOMD-Blue ( http://codeblue.umich.edu/hoomd-blue/ ) should be on your list.
hoomd lj_liquid_bmark.hoomd --mode=gpu
(in the benchmarks dir) will run the benchmark on the GPU, while
hoomd lj_liquid_bmark.hoomd --mode=cpu
will run the same job script on the CPU in a relatively well-optimized path.
If your goal is to demonstrate GPU speedup, then this recent thread has a lot of good advice. On the CPU side, in particular, you really need to build a multi-threaded version with some form of SSE (ideally SSE4) for the comparison to be valid.
Yes, this is my goal. But I am limited to “out of the box” solutions, as I have plenty of other stuff to write down, so I don’t have much time to check the code, try to compile etc. as this is not my primary occupation.
HOOMD is very good and even easier to use. Anything like this would be really cool. Like VMD, but I don’t know how to use it properly t benchmark (like in nV page).
I installed ubuntu 9.04 yesterday, then playing around nv drivers, then I installed CUDA toolkit, and then system path got somehow corrupted. No bin commands, nothing. Will try tomorrow again.
Could you tell me in quick steps how to run and benchmark with this Parboil?
