Best Cluster Dashboard?
OK, so I have seen various dashboard screenshots for spark clusters. But which to choose, ideally I want:
  1. Something that doesn’t actually run on the GB10 systems themselves. I don’t mind if it uses passwordless ssh to gather metrics. But the backend / frontend shouldn’t run on the GB10.
  2. Something that supports Clusters (for me that means 2 GB10s, for others perhaps more)
  3. I would like to see a wealth of metrics in real time, and also like to be able to go back in time.
  4. Web based, things that look like Grafana.
  5. Easy deployment, docker - launch - configure IPs / hostnames somewhere.
What are people using?
nv-monitor in background mode serving the metrics which are then viewed via Prometheus/Grafana.
Yes that looks quite small. Can it run as a service through systemd?
Then I guess I can just get an agent to build me a grafana docker which queires this plus the vllm metrics on top.
Just wondering about whether to rewrite the wheel, or use a prebuilt one that already is fleshed out.
So I have done just that, installed “nv-monitor” as a background service on all my nvidia enabled systems, and got GLM-5.3 to produce a docker and some example dashboards to query and run on another machine, sure it lacks some pazaz right now. But yet another dashboard solution to add to the mix.
