I read there is no mirror equivalent in OpenACC. I am wondering about the best way to “translate” it in OpenACC. Starting from a trivial example:
module storage
integer, parameter :: N=1000
real, dimension(:,:), allocatable :: A,B,C
!$acc mirror(A,B,C)
end module storage
subroutine matadd_sub()
use storage; implicit none
integer :: i,j
!$acc region
do i=1,N
do j=1,N
C(i,j) = A(i,j) + B(i,j)
enddo
enddo
!$acc end region
end subroutine matadd_sub
program matadd
use storage ; implicit none
allocate(A(N,N),B(N,N),C(N,N))
A = 1. ; B = 2. ; C = 0.
!$acc update device(A,B)
call matadd_sub()
!$acc update host(C)
print*,"C: ",C(6,3)
end program matadd
I think a possibility is:
module storage
end module storage
integer :: i,j
!$acc kernels loop present(A,B,C)
do i=1,N
do j=1,N
enddo
enddo
!$acc end kernels
program matadd
!$acc data region copyin(A,B) copyout(C)
call matadd_sub()
!$acc end data region
print*,"C: ",C(6,3)
end program matadd
It seems to work with PGI 12.3. But I would prefer much something like
module storage
!$acc declare device_resident(A,B,C) ! I do not know the clause
end module storage
integer :: i,j
!$acc kernels
do i=1,N
do j=1,N
enddo
enddo
!$acc end kernels
program matadd
call matadd_sub()
print*,"C: ",C(6,3)
end program matadd
This second version seems to be incorrect. Is it possibile to do modify it to make it working?
thanks in advance,
Francesco
