Best power supply for JAO 64GB
I am using the 64 GB devkit. When I run some computationally heavy workloads, I get the warning: System throttled due to over curent. I am using the USB-C power supply provided with the devkit. If this is not enough, what should be the specs of the power supply to provide enough power to run without throttling? Would it be a barrel jack connector?
The over current warning is caused by workload not by the power supply capability. It is to protect system. A higher voltage level could help, but still may meet the warning due to heavy workload.
