Hello everyone,
I’ve spent quite some time researching this topic but would really appreciate some insights from the experts here.
Use Case:
We have an Unreal Engine project that uses Pixel Streaming to deliver real-time rendered content to end users via the browser. Each user requires their own instance of the app. We’ve already containerized the project (Docker) and GPU passthrough works perfectly.
Challenge:
We want to dynamically scale up and down the number of running instances depending on user demand. Ideally, we’d like to schedule/manage these instances with Kubernetes, using the Nvidia Container Toolkit. The goal is to run multiple instances of the app on a single GPU.
What I’ve found so far:
- MIG (Multi-Instance GPU):
Doesn’t support Vulkan or DirectX APIs, so not suitable for real-time rendering with Unreal/Unity. - Nvidia vGPU:
Requires real virtualization (full VMs), which feels like overkill for our container-based setup and adds significant complexity. - Docker GPU time-slicing:
Doesn’t seem performant enough for real-time rendering workloads.
What I’m looking for:
- “Real” GPU partitioning (ideally hardware-based, but container-friendly) that works with Vulkan/DirectX.
- Preferably also with NVENC support for encoding (for pixel streaming, although I saw only 2 streams can be encoded at the same time, maybe this can be worked around with software encoding or a pixel streaming server)
- Ideally manageable via Kubernetes/Nvidia Container Toolkit.
The Big Question:
What do you recommend for running multiple concurrent, isolated instances of an Unreal or Unity (remote rendering) app, on a single GPU, where each instance needs full API support (Vulkan/DirectX) and ideally access to NVENC?
Are there solutions, best practices, or workarounds that you’d suggest? Or is this just not feasible with current Nvidia hardware/software?
Which Nvidia Hardware is recommended? I think the best fit would be a L40 or L40s?
Any experiences or links to relevant resources would be greatly appreciated!
Thanks in advance for your help!
