Best SBC to run heavy Cuda-based program in rugged environment
Currently I am developing a vision program that needs to be used in the agricultural sector. The program is currently running on a Nvidia Jetson AGX Xavier, which can handle the computing quite nicely. But the AGX Xavier is not really suited to be used in such a rugged environment, so I am looking to replace de development kit with another SBC.
So my question is: Are there any other SBC’s which have the computing power of the AGX Xavier and are Cuda-compatible, but are made to handle more rugged environments?
I have looked into the Nvidia Jetson AGX Xavier Industrial and it probably will be a good replacement, but I want to know all the options before I choose to buy pricey equipment.
P.s. I know there is a huge chip-shortage, so stock will be very limited, but this change is for the future and can wait several months before being implemented.
Hi @Epsi, you can find production systems/enclosures for AGX Xavier (and AGX Xavier Industrial) on this page:
https://developer.nvidia.com/embedded/community/jetson-partner-products?t1_hardware-solution=Full+System&t1_supported-jetson=AGX+Xavier
Depending on the level of ruggedization that you need, some of them are MIL-spec - for example:
Hi Dusty,
Thank you for your answer, this is exactly what I am looking for!
