Best way to configure #defines for a kernel
My kernel is stored in a .h file, which I include into a .cu file, where the kernel is actually invoked
with triple chevrons. The .h file is expecting a number of #defines that I would like to programatically set for different instances of the kernel. This kernel is a port from OpenCL, where I could set the #defines when I built the kernel from source.
Here is what I would like to be able to do :
#include "my_kernel.h"
#define FOO 1
#define BAR 2
my_kernel<<<...>>>(...);
#define FOO 3
#define BAR 4
Is this possible, and if so what is the best approach ?
I think the C++ way to do this is probably templating.
template <int FOO, int BAR>
__global__ void k(int *d){
   *d = FOO+BAR;
int main(){
  int *d = NULL;
  my_kernel<1,2><<<1,1>>>(d);
  my_kernel<3,4><<<1,1>>>(d);
If the kernel code itself is depending on FOO/BAR, your suggestion wouldn’t work anyway (even if you used #undef).
Thanks, @Robert_Crovella , I did try templating and it worked. For some #defines, I can’t get away with that as they determine which types are used in the kernel. So, in these cases, I will need separate .cu files, and will
put the #defines before the header inclusion.
templating can also control the types used by a kernel
template <typename T>
__global__ void k(T *d){ };
templating is a C++ concept, not unique or specific to CUDA
Thanks, that’s true, hadn’t thought of that.
