Best way to implement dual ethernet in Xavier NX
I am looking to create a carrier board for the Jetson Xavier NX that includes 2 x gigabit ethernet ports. The module only has 1 as default - what is the best/standard approach to implement a second port? I have seen you can buy a development board with 2 ports so assume it is possible.
We have no recommendation on this. Maybe you can check that online or with some vendor for converter device, like PCIe/USB to Ethernet, or switch. Also you can check with the vendors in ecosystem: Jetson Ecosystem | NVIDIA Developer
