Bfloat is Not Supported
Greetings,
>>> torch.cuda.is_bf16_supported()
False
While using these configs:
nvcc --version
Copyright (c) 2005-2023 NVIDIA Corporation
Built on Fri_Sep__8_19:17:24_PDT_2023
Cuda compilation tools, release 12.3, V12.3.52
Build cuda_12.3.r12.3/compiler.33281558_0
nvidia-smi
Thu Apr 25 20:55:51 2024
| NVIDIA-SMI 545.23.06              Driver Version: 545.23.06    CUDA Version: 12.3     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  Tesla V100-SXM2-32GB           Off | 00000000:62:00.0 Off |                    0 |
| N/A   33C    P0              54W / 300W |      0MiB / 32768MiB |      1%      Default |
|                                         |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                            GPU Memory |
|        ID   ID                                                             Usage      |
|  No running processes found                                                           |
What do you advise?
v100 does not support bfloat. bfloat support was introduced with ampere GPUs.
If you want to use V100, you cannot use bfloat.
