I have written a program that solves system of linear equations using the iterative method bi-conjugate gradient(BiCG). The program calls a function “ssbBiCG” which is part of a library “gpuBiCG”. But I am getting linked errors. The linked error as shown below is due to problems with linking cublas. I am using VS 2008 with x64 CUDA 4.0. I have included the header file(BiCG.h) from gpuBiCG and cublas.h. I have also linked with cublas.lib and gpuBiCG.lib. Any advise in the right direction will be greatly appreciated.
2>Linking...
2>LINK : warning LNK4098: defaultlib 'LIBCMT' conflicts with use of other libs; use /NODEFAULTLIB:library
2>gpuBiCG.lib(sBiCG.obj) : error LNK2019: unresolved external symbol cublasFree referenced in function "int __cdecl ssbBiCG(int,float *,int,struct float2 *,int,float)" (?ssbBiCG@@YAHHPEAMHPEAUfloat2@@HM@Z)
2>gpuBiCG.lib(sBiCG.obj) : error LNK2019: unresolved external symbol cublasCaxpy referenced in function "int __cdecl ssbBiCG(int,float *,int,struct float2 *,int,float)" (?ssbBiCG@@YAHHPEAMHPEAUfloat2@@HM@Z)
2>gpuBiCG.lib(sBiCG.obj) : error LNK2019: unresolved external symbol cublasScnrm2 referenced in function "int __cdecl ssbBiCG(int,float *,int,struct float2 *,int,float)" (?ssbBiCG@@YAHHPEAMHPEAUfloat2@@HM@Z)
2>gpuBiCG.lib(sBiCG.obj) : error LNK2019: unresolved external symbol cublasCdotu referenced in function "int __cdecl ssbBiCG(int,float *,int,struct float2 *,int,float)" (?ssbBiCG@@YAHHPEAMHPEAUfloat2@@HM@Z)
2>gpuBiCG.lib(sBiCG.obj) : error LNK2019: unresolved external symbol cublasCcopy referenced in function "int __cdecl ssbBiCG(int,float *,int,struct float2 *,int,float)" (?ssbBiCG@@YAHHPEAMHPEAUfloat2@@HM@Z)
2>gpuBiCG.lib(sBiCG.obj) : error LNK2019: unresolved external symbol cublasAlloc referenced in function "int __cdecl ssbBiCG(int,float *,int,struct float2 *,int,float)" (?ssbBiCG@@YAHHPEAMHPEAUfloat2@@HM@Z)
