Description
infer my onnx model using tensorrt resulting in bad outputs, while infer using onnxruntime is good for the same onnx model and inputs
Environment
TensorRT Version: 10.8
GPU Type: GTX3090
Nvidia Driver Version: 525.105
CUDA Version: 12.0.1
CUDNN Version: 8
Operating System + Version: ubuntu2204 docker on ubuntu1804 host
Python Version (if applicable): 3.10.12
TensorFlow Version (if applicable): N/A
PyTorch Version (if applicable): N/A
Baremetal or Container (if container which image + tag): nvidia/cuda:12.0.1-cudnn8-devel-ubuntu22.04
Relevant Files
my_sample.zip (25.8 MB)
Steps To Reproduce
Download the attached my_sample.zip, unzip it under TensorRTOSS10.8/samples/python/
(the onnx model needs passwd to unzip: wrongtensorrtresult)
the network in onnx is an object detection network which output a heatmap representing the center point of objects, the test.npy is saved tensor after pre-processing some image.
`python run_onnx.py hm.onnx test.npy`
it will save two png outputs, you can see the trt output is different from onnx output. the onnx output png is correct as it shows 3 dots which represents 3 objects, while the trt output shows all black
`polygraphy run hm.onnx --trt --onnxrt --atol 0.001 --rtol 0.001`
or you can add “–data-loader-script data_loader.py” which reads test.npy as input
you can see the compare fails with large difference
