flyfrog
September 4, 2009, 1:10pm
1
here’s a simple code,which will cause a terrible runtime error
black screen, after that, thousands colorful dot on my screen
what casue the problem?
i call the kernel by
test<<<8,256>>>()
[codebox]
global void test()
int PartIdx;
PartIdx = blockIdx.x*blockDim.x + threadIdx.x;
shared float a[2048];
for (int i=0;i<100000000;i++){
a[PartIdx]=1.0f;
[/codebox]
and this code won’t get any error
i have really no idea what’s the problem is…
[codebox]
global void test()
int PartIdx;
a[0]=1.0f;
[/codebox]
LSChien
September 4, 2009, 4:09pm
2
test<<<8,256>>>()
[codebox]
global void test()
int PartIdx;
a[PartIdx]=1.0f;
[/codebox]
[codebox]
global void test()
int PartIdx;
a[0]=1.0f;
[/codebox]
I test your code on my computer
winxp pro64, vc2005, Tesla C1060, driver 190.38, cuda2.3
your setting ( test<<<8,256>>>() ) requires 9 s, program works fine.
also I use one GPU of GTX295 to test your code, it costs 9.5 s and works fine.
I think that this is watchdog problem
could you use deviceQuery in SDK example to check your configuration?
find some field “Run time limit on kernels:”
if this field is yes, then you have watchdog problem.
flyfrog
September 5, 2009, 2:48am
3
thank you, i’ll try it next Monday
safars
September 5, 2009, 9:38am
4
If you’re using Vista, I think they have a fixed limit on the maximum runtime of kernels / graphics driver calls, not only for CUDA but DirectX etc. also.
[url=“http://www.microsoft.com/whdc/device/display/wddm_timeout.mspx ”]http://www.microsoft.com/whdc/device/displ...dm_timeout.mspx[/url]
Maybe the first code couldn’t be optimized that much, and so didn’t stay inside the time limit. (Does the blank screen occur only after a few seconds? And how long does the first version run?)
flyfrog
September 5, 2009, 12:19pm
5
http://www.microsoft.com/whdc/device/displ…dm_timeout.mspx
thank you for reply
i’m using windows 7, enterprise version
I just wanna understand what the problem is, so I may find a different way to organize my algorithm.
the blank screen occurs only after a few seconds, yeah
the first version runs for a few seconds before blank screen occurs. I also try it under linux, it runs ok and takes about 10s, so I think it could be the watchdog problem
flyfrog
September 7, 2009, 5:27am
6
strange things is
devicequery returns this:
Concurrent copy and execution: Yes
Run time limit on kernels: No
Integrated: No
Support host page-locked memory mapping: Yes
does this mean i should not have a run time limit??
