Bilateral Filter on GPU Can somebody please help
I am an undergraduate student at IIT Bombay and working on implementing image processing algorithms in GPU. I am writing a code to implement bilateral filter on GPU using the brute force method. But the program is giving segmentation error. Can someone please point out the error… i am new to CUDA and there are not many ppl here to help me out.
I am pasting my kernel and host codes here. I have my presentation next week and I need to show a working code. please help me out.
Code:
[codebox] #include <stdlib.h>
#include <stdio.h>
#include <cutil.h>
//Kernel
texture<float, 2, cudaReadModeElementType> tex;
global void BilateralFilter(float* outputImage, float* d_kernel, int kernelRad, float sigmar, int width, int height) {
int i = blockIdx.x*blockDim.x + threadIdx.x;
int j = blockIdx.y*blockDim.y + threadIdx.y;
float in = (float) i/width; float jn = (float) j/height;
float ival0 = tex2D(tex, in, jn);
float ival = 0.0;
float rangFilt = 0.0;
float weight = 0.0;
float out = 0.0;
float temp = 0.0;
for (int ti = -kernelRad; ti <= kernelRad; ti++) {
	for (int tj = -kernelRad; tj <= kernelRad; tj++) {
		in = (float) (i + ti)/width;
		in = fmax(0.0, in);
		in = fmin(in, 1.0);
		jn = (float) (j + tj)/height;
		jn = fmax(0.0, jn);
		jn = fmin(1.0, jn);
		ival = tex2D(tex, in, jn);
		rangFilt = expf(-(ival - ival0)*(ival - ival0)/(sigmar*sigmar));
		temp = rangFilt*d_kernel[(ti + kernelRad) + (2*kernelRad + 1)*(tj + kernelRad)];
		out += temp*ival;
		weight += temp;
outputImage[i + j*width] = out/weight;
//Main Program
int main() {
//Start the timer
unsigned int timer = 0;
CUT_SAFE_CALL(cutCreateTimer(&timer));
CUT_SAFE_CALL(cutStartTimer(timer));
//Loading input image
char* image_file = “test.pgm”;
float* image = NULL;
unsigned int width = 0, height = 0;
int sizeI = widthheightsizeof(float);
CUT_SAFE_CALL(cutLoadPGMf(image_file, &image, &width, &height));
//Binding Image to Texture Memory
cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc(32, 0, 0, 0, cudaChannelFormatKindFloat);
cudaArray* cu_array;
CUDA_SAFE_CALL(cudaMallocArray( &cu_array, &channelDesc, width, height));
CUDA_SAFE_CALL(cudaMemcpyToArray(cu_array, 0, 0, image, sizeI, cudaMemcpyHostToDevice));
// set texture parameters
tex.addressMode[0] = cudaAddressModeClamp; //out-of -range texture coordinates will be clamped to the valid range
tex.addressMode[1] = cudaAddressModeClamp;
tex.filterMode = cudaFilterModeLinear;
tex.normalized = true;
// Bind the array to the texture
CUDA_SAFE_CALL(cudaBindTextureToArray(tex, cu_array, channelDesc));
//Filter Characteristics
int sigmad = 1;
float sigmar = 0.1;
int kernel_width = 4*sigmad + 1;
int KERNEL_SIZE = kernel_width*kernel_width*sizeof(float);
float* h_kernel = (float*) malloc(KERNEL_SIZE);
for (int i = 0; i < kernel_width; i++) {
	for (int j = 0; j < kernel_width;  j++) {
		h_kernel[i + j*kernel_width] = expf((-(i - 2*sigmad)*(i - 2*sigmad) - (j - 2*sigmad)*(j - 2*sigmad))/(sigmad*sigmad));
float* d_kernel;
cudaMalloc((void**) &d_kernel, KERNEL_SIZE);
CUDA_SAFE_CALL(cudaMemcpy(d_kernel, h_kernel, KERNEL_SIZE, cudaMemcpyHostToDevice));
//Output Image Array
float* outputImage;
cudaMalloc((void**) &outputImage, sizeof(sizeI));
dim3 Grid(8, 8, 1);
dim3 Block((int) width/Grid.x - 1, (int) height/Grid.y - 1);
BilateralFilter<<<Block, Grid>>> (outputImage, d_kernel, 2*sigmad, sigmar, width, height);
//Copying Output to device
float* output = (float*) malloc(CUDA_SAFE_CALL(cudaMemcpy(output, outputImage, sizeI, cudaMemcpyDeviceToHost));
//writing output image
char* out_file = "output.pgm";
CUT_SAFE_CALL(cutSavePGMf(out_file, output, width, height));
//stop the timer and print output
CUT_SAFE_CALL(cutStopTimer(timer));
printf("Processing time: %f (ms)\n", cutGetTimerValue(timer));
CUT_SAFE_CALL(cutDeleteTimer(timer));
return 0;
} [/codebox]
Segmentation error means you’re doing something wrong in Host code. If you use any kind of debugger, it should tell you the line that’s causing it.
Btw, wth is this supposed to mean:
sorry, the actual host code lines are…
float* d_kernel;
float* outputImage = NULL;
<b>cudaMalloc((void**) &outputImage, sizeI);</b>
dim3 Grid(8, 8, 1);
dim3 Block(width/Grid.x, height/Grid.y, 1);
[b]BilateralFilter<<<Block, Grid>>> (outputImage, d_kernel, 2*sigmad, sigmar, width, height);
[/b]
float* output = (float*) malloc(sizeI);
<b>CUDA_SAFE_CALL(cudaMemcpy(output, outputImage, sizeI, cudaMemcpyDeviceToHost));</b>
i have figured out that the code runs smoothly when i do not assign outputImage value in the kernel code, as:
                                   outputImage[i + j*width] = (float) out/weight;
like if i write outputImage[0] = (float) out/weight the code runs…
but i am not being able to figure out why this is happening because i am allocating correct size for outputImage…
also one more trouble is that the value of output variable I am getting is zero, for example when I copied outputImage[0] to host… even though I am not using double variables in my code…
btw thanks for your patience to read thru all the code…
I don’t know, it looks like you’re doing things right.
Standard procedure for debugging things like this is to comment everything out until something works, then comment things back in line by line until it doesn’t. Remember to do this from both ends of a function, and keep in mind the compiler will optimize out dead code. Also, have you tried emulation mode? What OS are you using?
I am using fedora linux and NVIDIA 8600 graphics card… thanks for the debugging suggestion… one more thing… can you suggest me why I am getting 0.0000 in my host memory when I use cudaMemcpy to copy from device to host memory. Not only in this program, I also tried defining float variables in other programs also and copy them back to host memory… but I get 0.000 irrespective of the value I have assigned in the kernel code.
Like I said, start with the smallest CUDA program you can write and see if it works. If it doesn’t, you can post it here and it’ll be easier to see what’s wrong.
