hi everyone,
since i am very new to gpu programming, i would be glad if anyone could give me some help.
I have implemented a bilateral filter running on the CPU and wanted to change the implementation to run on a GPU, but i have no clue how to start.
void bilateralBlur(IplImage* input_img, IplImage* output_img, int sigmaS, int sigmaR)
// Create Gaussian/Bilateral filter --- mask ---
int length = 9;
std::vector<float> mask(length);
for (int i = 0; i < length; i++)
mask[i] = exp(-0.5*((i*i)/(sigmaS*sigmaS)));
//fprintf( stderr, "i = %d, value= %f \n", i, mask[i]);
int m_width = input_img->width ;
int m_height= input_img->height ;
//ImageData
uchar* src_img= (uchar*) input_img->imageData ;
//Ausgangs bild ist genau so groß wie das Eingangsbild!
uchar* dst_img =(uchar*) output_img->imageData ;
double wp, k;
//evtl. mit y=-length/2; y<=m_height-length/2; y+=4
for(int y=0; y<m_height; y+=1)
for (int x=0; x<m_width; x+=1){
int centerPix =x + y*m_width;
for (int j=-length/2;j <=length/2;j+=1){
for (int i=-length/2;i<=length/2;i+=1){
int curPix = x+i+(y+j)*(m_width);
//spatial diff
double delta = sqrt(i*i+j*j);
double euklidDiff=exp(-0.5 * pow(delta/sigmaS,2));
double intens = src_img-src_img[curPix];
double factor = exp(-0.5 * pow(intens/sigmaR,2)) * euklidDiff;
wp += factor * src_img[curPix];
k += factor;
dst_img = wp/k;
wp=0;
k=0;
I dont need the whole scource code but some hints. So I would really be glad i anyone could give me some tipps or code fargments.
Yours,
ibi
