Bin files missing from Sample Driveworks-2.2 in Xavier - B
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
Target Operating System
Linux
Hardware Platform
SDK Manager Version
1.4.0.7363
Host Machine Version
native Ubuntu 18.04
We have been trying to run the samples from driveworks-2.2 on AGX -Pegasus Xavier- B , But we noticed the Bin files missing in the driveworks-2.2.
The Driveworks-2.2 for Xavier A works Fine. not sure if the issues is related to flashing or it needs to be cross complied in the host PC first then transfered to make it work?
Dear @vimal.prasath ,
It is expected as Driveworks bin samples are shipped on only Xavier A, please check release notes(https://developer.nvidia.com/DRIVE/secure/docs/NVIDIA_DRIVE_Software_Release_Notes_10.0.pdf)
hi,
Do we need to cross compile it on Xavier-B?
How to install deep learning libraries on Xavier (libraries such as PyTorch, Opencv-Python, Tensorflow)? I tried installing using pip but it haven’t worked.
Thanks and regards.
Dear @vimal.prasath,
Yes. you need to cross compile the sample. We do not officially support PyTorch/TF/OpenCV on DRIVE AGX platform. You may check native installation from source.
We recommend using TensorRT for optimal performance.
hi,
I am getting this error on Xavier-B
ImportError: libcudart.so.10.0: cannot open shared object file: No such file or directory.
Could you please a seperate topic for new issues to avoid cluttering of topics.
sure.
