Hi Everyone,
I’m trying to convert a program currently using global memory to one using texture fetches. Is it possible to bind textures to global device variables? As an example, I have the following code:
__device__ float cell_vars[num_cells*num_hydro_vars];
texture<float> tex;
cudaBindTexture(tex, cell_vars, (num_cells*num_hydro_vars*sizeof(float)), 0);
But the cudaBindTexture() call fails. I can get the call to work if I do instead
void *devPtr;
cudaGetSymbolAddress(&devPtr, cell_vars[0]);
cudaBindTexture(tex,devPtr,(num_cells*num_hydro_vars*sizeof(float)), 0);
But then, texfetch does not return the same values as direct access to cell_vars does… Does anyone have a suggestion for what might be wrong?
Thanks,
Peter
