binning with kernel newbie about implement loop to kernel
Hi All,
I have a Complex array (batchsizennsizeof(Complex) ), and I would like to bin its squares in a float array (nn*sizeof(float)).
If I do this with host variables, its simple:
typdef float2 Complex;
void ComplexPufferToReal(Complex *h_signal, float *h_puffer, int batchsize, int nn)
    int k, j;
    for (j=0;j<nn*batchsize;j++)
    h_puffer[k] += (h_signal[j].x * h_signal[j].x) + (h_signal[j].y * h_signal[j].y);
    k++;
    if (k>nn-1) k = 0;
This one works just fine on the host. But I would like to do this binning on the device since I have to do this many times in a loop after an cudaFFT function.
I tried to implement the above function to a kernel so it would work on device variables (allocated with cudaMalloc, and zero-d with cudaMemset):
__global__ void ComplexPufferToReal(Complex *d_signal, float *d_puffer, int batchsize, int nn)
  int k=0;
  int j = blockIdx.x*blockDim.x + threadIdx.x;
  if (j<batchsize*nn)
    d_puffer[k] += (d_signal[j].x * d_signal[j].x) + (d_signal[j].y * d_signal[j].y);
    k++;
    if (k>nn-1) k = 0;
calling like this for example:
int batchsize = 1000;
int nn = 512;
int Nofmaxthreads = 512;
int nBlocks = (batchsize*nn)/Nofmaxthreads + ((batchsize*nn)%Nofmaxthreads == 0 ? 0 : 1);
ComplexPufferToReal<<<nBlocks, Nofmaxthreads>>>(d_signal, d_puffer, batchsize, nn);
I think I mixed up something, this is not working like the one above, somebody please could help me, how to do the above simple loop with device variables in a kernel? (I have a Gefore8600GT, WinXP, VS2003+nvcc)
Thanks very much in advance :) ,
Regards,
András
The value of k in the kernel is equal to 0 for every write to d_puffer.
upss, i made a really really primitive error :haha:
thanks very much for the answere! :)
Regards.
