I need to generate lots of random numbers in parallel using Binomial Distribution on CUDA. All the Random Number Generators on CUDA are based on the Uniform Distribution (as far I know), what is also useful since all the algorithms for Binomial Distribution needs to use Uniform variates.
Is there any library or implementation for binomial random variate generation on CUDA? I see that there are for JAVA in http://acs.lbl.gov/~hoschek/colt/ , but it uses a very complicated algorithm to be parallelized. However, given a binomial variate following B(N,p), there are simpler algorithms with order of complexity O(N), but it is bad for me because N can be large (around 2^32, maximum for a Integer).
I would appreciate any help.
Thanks a lot.
Miguel
