I’ve add the log from nvidia-bug-report.sh
I first tried to install .run file from nvidia website => black screen
Remove ever nvidia package => apt purge nvidia*
Then install from Additional software and ubuntu-drivers
It is the same result each time, I reboot, get a black screen. I’m able to switch to teminal with CTRL-ALT-F1 and I’m able to swtich between intel and nvidia driver with prime-select
Now I have either a black screen with nvidia driver or a GUI in low resolution and two screens detected with nouveau driver.
Need help to solve this problem
Thanks,
nvidia-bug-report.log (1.3 MB)
It’s an Optimus notebook, so you can’t use the .run installer.
Please follow this:
- remove the .run installer driver using the --uninstall option
- delete /etc/X11/xorg.conf
- install the driver from repoo (sudo apt install --reinstall nvidia-driver-390)
- make sure nvidia-prime is installed (sudo apt install nvidia-prime)
- switch to nvidia (sudo prime-select nvidia)
- remove stray blacklist files (sudo rm /lib/modprobe.d/blacklist-nvidia.conf /etc/modprobe.d/blacklist-nvidia.conf)
- update the initrd (sudo update-initramfs -u)
- reboot
If this doesn’t resolve the issue, please create a new nvidia-bug-report.log.
Than you generix!
It works on nvidia driver now :)
I have another question related to my graphic card
I try to run vulkaninfo but I get:
N53SM:~$ vulkaninfo
/build/vulkan-tools-136mCR/vulkan-tools-1.1.126.0+dfsg1/vulkaninfo/vulkaninfo.h:399: failed with ERROR_INITIALIZATION_FAILED
N53SM:~$ sudo vulkaninfo
error: XDG_RUNTIME_DIR not set in the environment.
Is my graphic card compatible?
How to make vulkaninfo works on my laptop?
Thanks,
