Black screen after install of nvidia driver ubuntu
Hi, same issue, fresh ubuntu installation, planned on using in tty mostly. Black screen after installing nvidia drivers. Can connect over ssh, so got details from there:
nvidia-detector
nvidia-driver-470
nvidia-smi
Sun Jan  8 10:27:21 2023
| NVIDIA-SMI 470.161.03   Driver Version: 470.161.03   CUDA Version: 11.4     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:01:00.0 N/A |                  N/A |
| 40%   36C    P0    N/A /  N/A |      0MiB /  2001MiB |     N/A      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
inxi -Gx --display
 Graphics:
   Device-1: Intel IvyBridge GT2 [HD Graphics 4000] vendor: ASRock
     driver: i915 v: kernel arch: Gen-7 bus-ID: 00:02.0
   Device-2: NVIDIA GK208B [GeForce GT 730] vendor: Gigabyte driver: nvidia
     v: 470.161.03 arch: Kepler bus-ID: 01:00.0
   Display: server: X.org v: 1.21.1.4 driver: X: loaded: nvidia
     gpu: i915,nvidia tty: 151x85
   Message: GL data unavailable in console for root.
nvidia-bug-report.log at bug report at https://termbin.com/vpwp
dpkg -l | grep nvidia | nc termbin.com 9999 at https:termbin.com/oaj6
Thanks a lot for your help
Have you found solution for this i am also getting same problem
I never found a solution. I resorted to using the integrated graphics instead of the NVIDIA gpu. I have switched back to using the NVIDIA gpu in ā€˜On Demand’ mode and haven’t had an issue in a while. I’m guessing whatever bug caused the problem has been fixed by a driver update.
I tried using NVIDIA GPU in ā€˜On Demand’ mode but still it goes black screen , I am using driver version 535
I’m experiencing the same issue on my HP Victus laptop (13th Gen i7, GeForce RTX 4060). My system is dual-booted with Windows and Ubuntu 20.04. I installed NVIDIA drivers (version 560) using the following commands:
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo ubuntu-drivers autoinstall
I’ve attached the nvidia-bug-report.log.gz file for reference. Any help would be greatly appreciated. Thanks in advance!
nvidia-bug-report.log.gz (341.3 KB)
