Whenever I close the laptop lid and wait for it to suspend, and then open it again, the screen shows a console cursor on the top left briefly, and then goes black. It does not respond to any keyboard or mouse input. I can still ssh into the machine and see that Xorg is using 100% of one CPU.
I’ve had this problem for a few months through multiple kernel, Xorg and drive updates, and I’ve posted in another thread about a similar problem. Sandip asked me to start a separate thread.
Here’s the nvidia-bug-report output generated when I ssh into the machine:
https://paste.pound-python.org/show/jWsl1aH1kudtlagRnhF5/
There is no any nvidia related error in log. Is any older driver worked on your setup? What desktop env you are running gnome, kde , unity or else? Looks like you are running MShybrid notebook which has intel and nvidia gpu. How did you configured PRIME on this notebook? Please share output of xrandr and xrandr --verbose commands.
I am running KDE. The laptop has Intel and NVIDIA, and I did configure PRIME synchronization with
xrandr --setprovideroutputsource modesetting NVIDIA-0
xrandr --auto
The problem started a few months ago, but before that I used the Intel card with Bumblebee. At that time I also had a problem of not being able to use the NVIDIA card after resume, but the system did not freeze.
xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
eDP-1-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
1920x1080 60.01*+
1400x1050 59.98
1280x1024 60.02
1280x960 60.00
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
800x600 60.00 60.32 56.25
700x525 59.98
640x512 60.02
640x480 60.00 59.94
512x384 60.00
400x300 60.32 56.34
320x240 60.05
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected (normal left inverted right x axis y axis)
xrandr --verbose
eDP-1-1 connected primary 1920x1080+0+0 (0x46) normal (normal left inverted right x axis y axis) 344mm x 194mm
Identifier: 0x42
Timestamp: 40781
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1 2
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff0009e5b90600000000
011a010495221378023d78995b549127
224e5300000001010101010101010101
0101010101013c3780de703814403020
360058c21000001a0000000000000000
00000000000000000000000000fe0042
4f452048460a202020202020000000fe
004e5631353646484d2d4e34360a0082
PRIME Synchronization: 1
supported: 0, 1
scaling mode: Full aspect
supported: None, Full, Center, Full aspect
Broadcast RGB: Automatic
supported: Automatic, Full, Limited 16:235
audio: auto
supported: force-dvi, off, auto, on
1920x1080 (0x46) 141.400MHz +HSync -VSync *current +preferred
h: width 1920 start 1968 end 2000 total 2142 skew 0 clock 66.01KHz
v: height 1080 start 1083 end 1089 total 1100 clock 60.01Hz
1400x1050 (0x47) 122.000MHz +HSync +VSync
h: width 1400 start 1488 end 1640 total 1880 skew 0 clock 64.89KHz
v: height 1050 start 1052 end 1064 total 1082 clock 59.98Hz
1280x1024 (0x48) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1280x960 (0x49) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1024x768 (0x4a) 133.475MHz -HSync +VSync DoubleScan
h: width 1024 start 1100 end 1212 total 1400 skew 0 clock 95.34KHz
v: height 768 start 768 end 770 total 794 clock 60.04Hz
1024x768 (0x4b) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
960x720 (0x4c) 117.000MHz -HSync +VSync DoubleScan
h: width 960 start 1024 end 1128 total 1300 skew 0 clock 90.00KHz
v: height 720 start 720 end 722 total 750 clock 60.00Hz
928x696 (0x4d) 109.150MHz -HSync +VSync DoubleScan
h: width 928 start 976 end 1088 total 1264 skew 0 clock 86.35KHz
v: height 696 start 696 end 698 total 719 clock 60.05Hz
896x672 (0x4e) 102.400MHz -HSync +VSync DoubleScan
h: width 896 start 960 end 1060 total 1224 skew 0 clock 83.66KHz
v: height 672 start 672 end 674 total 697 clock 60.01Hz
800x600 (0x4f) 81.000MHz +HSync +VSync DoubleScan
h: width 800 start 832 end 928 total 1080 skew 0 clock 75.00KHz
v: height 600 start 600 end 602 total 625 clock 60.00Hz
800x600 (0x50) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x51) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
700x525 (0x52) 61.000MHz +HSync +VSync DoubleScan
h: width 700 start 744 end 820 total 940 skew 0 clock 64.89KHz
v: height 525 start 526 end 532 total 541 clock 59.98Hz
640x512 (0x53) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 664 end 720 total 844 skew 0 clock 63.98KHz
v: height 512 start 512 end 514 total 533 clock 60.02Hz
640x480 (0x54) 54.000MHz +HSync +VSync DoubleScan
h: width 640 start 688 end 744 total 900 skew 0 clock 60.00KHz
v: height 480 start 480 end 482 total 500 clock 60.00Hz
640x480 (0x55) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
512x384 (0x56) 32.500MHz -HSync -VSync DoubleScan
h: width 512 start 524 end 592 total 672 skew 0 clock 48.36KHz
v: height 384 start 385 end 388 total 403 clock 60.00Hz
400x300 (0x57) 20.000MHz +HSync +VSync DoubleScan
h: width 400 start 420 end 484 total 528 skew 0 clock 37.88KHz
v: height 300 start 300 end 302 total 314 clock 60.32Hz
400x300 (0x58) 18.000MHz +HSync +VSync DoubleScan
h: width 400 start 412 end 448 total 512 skew 0 clock 35.16KHz
v: height 300 start 300 end 301 total 312 clock 56.34Hz
320x240 (0x59) 12.587MHz -HSync -VSync DoubleScan
h: width 320 start 328 end 376 total 400 skew 0 clock 31.47KHz
v: height 240 start 245 end 246 total 262 clock 60.05Hz
Identifier: 0x43
Timestamp: 40781
Subpixel: unknown
Clones:
CRTCs: 0 1 2
filter:
supported: 0, 1
aspect ratio: Automatic
supported: Automatic, 4:3, 16:9
audio: auto
Identifier: 0x44
Timestamp: 40781
Subpixel: unknown
Clones:
CRTCs: 0 1 2
filter:
supported: 0, 1
audio: auto
Please try with kernel option acpi_osi=“!Windows 2015”
If that doesn’t help, try acpi_osi=! acpi_osi=“Windows 2009”
Neither of these helped. I also tried acpi_osi=“!Windows 2009” and it didn’t help either.
Feared so. I’ve found an acpidump of your machine and had a look at it and it seems that it’s affected by this
[url]Invalid Bug ID
Unluckily, your machine doesn’t test for OS before invoking the critical method, so no workaround that I can see.
But my knowledge on this is limited so you’d better post there and attach your acpidump. Maybe Leykenstein can find a workaround.
Edit: there’s also the infamous “ACPI FADT declares the system doesn’t support PCIe ASPM, so disable it” message in your dmesg.
