Black screen + high fan speed when booting Ubuntu live USB with RTX 5060 Ti on B550 (no iGPU)
I am getting a black screen with high fan speed when trying to boot Ubuntu from USB with my RTX 5060 Ti.
System:
  • GPU: MSI GeForce RTX 5060 Ti 16GB SHADOW 2X OC PLUS GDDR7
  • Motherboard: ASUS TUF GAMING B550M-PLUS WIFI II (latest BIOS)
  • CPU: AMD Ryzen 7 5700X (no integrated graphics)
Issue:
  • GRUB menu appears normally.
  • After selecting “Try or Install Ubuntu”, the screen goes completely black.
  • Both CPU and GPU fans spin up to maximum speed immediately.
  • No display output.
What I have tried:
  • Boot parameters: nomodeset, pci=realloc=off, nouveau.modeset=0, pci=nocrs, acpi=off and combinations
  • BIOS: Secure Boot Disabled, CSM Disabled
  • Ubuntu 24.04 and 25.10 (amd64)
  • Different HDMI and DisplayPort cables
The GPU works perfectly in Windows 11.
My question:
Is there any working boot parameter or workaround to make the Ubuntu live session boot with the RTX 5060 Ti on a B550 board without using a temporary GPU?
Any help or suggestion would be appreciated. Thanks!
Hey,
You can try if POP-OS installer is able to start: it has NV proprietary drivers included (unlike Ubuntu that by default uses the open-source Nouveau).
Thanks for the suggestion.
Quick question: Since I have a Ryzen 7 5700X (no iGPU) and I’m getting black screen + high fan speed even on Ubuntu, do you think the Pop!_OS NVIDIA ISO will boot successfully with my RTX 5060 Ti on B550 motherboard?
Or should I still expect the same issue?
Last time I tried POP_OS was like back in 2025, so things may have changed since then, but generally I would bet that NV drivers have much better chances of properly handling Blackwell (50xx) than Nouveau. This is because it takes considerable amount of time to reliably rev-eng stuff by the open-source hackers and Blackwell is still a fairly new arch.
Thank you so much for the suggestion and detailed explanation! Really appreciate it.
I’ll try the latest Pop!_OS NVIDIA ISO now and see how it goes.
Thanks again!
Hey,
Thank you so much for the suggestion and explanation! Really appreciate it.
I tried the latest Pop!_OS NVIDIA ISO, but I’m getting this error on the live session:
[FAILED] Failed to start cosmic-greeter.service - COSMIC Greeter.
Screen is black after that and stuck.
Any idea how to fix this or bypass the cosmic greeter?
Thanks again!
