Summary
With the monitor set to DisplayPort 1.4 (DSC), the screen goes black as soon as nvidia-drm takes over the console during early boot (fbdev / Plymouth LUKS passphrase prompt). The system keeps running and the passphrase can be typed blindly. Once GNOME (Wayland) starts, the desktop comes up correctly at 3840x2160@144 Hz with DSC.
Forcing a non-DSC console mode with the kernel parameter video=1920x1080@60 (or video=3840x2160@60) works around it. Without it, the early-boot console is black on every boot.
The same hardware and cable path works with DSC on Windows and on CachyOS.
System
- GPU: NVIDIA GeForce RTX 3080 Ti (VBIOS 94.02.71.40.45)
- Driver: 615.71.09, open kernel modules (
nvidia-driver-615-open, Ubuntu package) - OS: Ubuntu 26.04.1 LTS, kernel 7.0.0-42-generic, Secure Boot enabled
- Desktop: GNOME Shell 50.1 (Wayland), mutter 50.1
- Initramfs: dracut 110, nvidia modules loaded early via
force_drivers+=" nvidia nvidia_modeset nvidia_uvm nvidia_drm " - Plymouth 24.004.60
- modprobe options:
nvidia_drm modeset=1,NVreg_PreserveVideoMemoryAllocations=1 - Monitor: LG 27GN950 (3840x2160, 144 Hz, DP 1.4 with DSC), firmware SV 3.17 (DDC/CI VCP 0xC9) / NV 5.61 (USB bcdDevice), manufactured 2022 week 4
- Connection: DisplayPort through a UGREEN KVM switch (model 55851); the same setup works with DSC on Windows and CachyOS
Steps to reproduce
- Set the monitor’s DisplayPort mode to “1.4 (DSC)”.
- Boot with nvidia-drm in the initramfs and no
video=parameter. - The UEFI POST screen, GRUB, and the first simpledrm messages display fine.
- When nvidia-drm initializes and fbcon switches to
nvidia-drmdrmfb, the monitor goes black. The Plymouth LUKS prompt is not visible. - Type the passphrase blindly. GNOME starts and the desktop displays correctly at 4K@144 with DSC.
Expected behavior
The fbdev console and Plymouth display a picture in the monitor’s preferred mode (4K@144 with DSC), or fall back to a mode that works.
nvidia-bug-report.log (2.0 MB)
Observations
- With
video=1920x1080@60orvideo=3840x2160@60(both work without DSC), the early-boot console is visible. - Monitor set to DP 1.2 (no DSC): everything works.
- The kernel log shows no errors when the screen goes black (no NVRM or nvidia-modeset errors).
- Driver 595.99.02 (open) was worse: with DSC, even the GNOME desktop stayed black. 615.71.09 fixed the desktop but not the early console.
- Not tested yet: proprietary (closed) kernel modules.
nvidia-bug-report.log.gz captured during a boot without the video= parameter, after unlocking blindly.
